Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
My Chamberlain ECO300 no longer respond to the remote control. Remotes appear to operate and the signal is received in training mode. The gates operate correctly when in manual learning mode. Infra red sensors disabled or enabled makes no difference
2 Suggested Answers
  • 244 Answers
SOURCE: Chamberlain 1/2 hp Model # 82000 remotes not working
get a referral to a garage door guy! First off, make sure you have not activated "Lock" on console. If not, recode remote by hitting LEARN button on motor for 1 second and pusjing a button on remote. Light bulb on motor should blink 2x. Repeat for each remote you are having problem with. Should do it.
Posted on Jan 14, 2009
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
My Liftmaster Formula 1 opener has stopped receiving signals. The wall switch operates the door, but remotes will not. Our 2nd door opener was east to program a new remote.
This sounds like a similar problem that I had. The circuit board on the garage door motor has a capacitor that goes bad and this prevents the remotes from working. You can either buy a replacement circuit board online (for around $80 if I remember) or if you can solder, simply replace the capacitor for a few dollars. I answered a similar question on this site before after I went through the process. There are more details there. The capacitor in question was close to a heat producing component and over time it cooks.
Sep 13, 2017 | liftmaster Chamberlain Garage Door Opener...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Transmitter Programming
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
Replaced batteries.changed codes verified not in lock position checked wiring-checked breakers -remotes dont work have 2 different units-one commercial all stopped working on same day -need help
I have the Same Problem...
2 similar but independent 315MHz Craftsman door openers stopped receiving any remote signals at the exact same time. One hour they worked , next hour they didn't, no storms in area.
I know remotes are good because they still open our subdivision gate. the Only way to open door is with wall pad. Verified that they are not on vacation lock. 5 different remotes, 2 different keypads all no longer open door.
I tried resetting codes with learn button but they won't take new programming. Also before when an unlearned remote was used in the area, the learn light would at least flicker (as if it was receiveng a code, but rejecting it) It no longer even does that.
i even cycled the circuit breaker and the vacation lock, no help.
Does anyone know how to fix this?
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Same: Only wall button works
It is your receiver that is bad and is part of the logic board. The remotes and keypad send a signal that the receiver uses to switch the relay that controls the motor. The wall control is wired directly and doesn't use the receiver. The key is both the remotes and keypad quit at the same time.
Sep 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
3 Chamberlain liftmaster openers suddenly won't accept remotes farther than 2' from antennaes. I cycled power on one of the units, erased all remote codes and tried to add remotes back in one at a time...
With multiple units, the possibilities are few. One is weak batteies. I am sure you have tried new ones in the remotes.???
Another thing is interference from another source. These operate in a band above 300 MHZ. A strong signal COULD cause the remotes to have to be very close tot the receivers to overide interference.
Aug 24, 2009 | Televison & Video
I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Jul 15, 2009 | Home Security
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
54 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
