Question about Cameras
Power shot s51s view screen turns white or is lost when its closed with screen out,can it be wire connection in hinge swivel can I fix myself?
SOURCE: view screen is white
go here
http://www.fixya.com/support/t228735-bright_white_screen
make sure you read to the bottom, where the solution is!
Posted on May 14, 2008
  • 17 Answers
SOURCE: Canon S51S power shot ... shutter stuck won't open . Help .
Either do a manual repair or take it in to a local servicer. Could just be some moisture built up inside.
Posted on Jan 04, 2009
t00nz
  • 4738 Answers
SOURCE: All I see in the view screen is a white screen. I
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jul 16, 2009
t00nz
  • 4738 Answers
SOURCE: I turn on my Canon Power shot A75. to take a
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Oct 14, 2009
  • 11 Answers
SOURCE: Need to know where to obtain manual for Canon
http://dl.owneriq.net/4/4696ea04-0d04-2854-5de4-050c8c52b34b.pdf
Posted on Mar 19, 2010
I have a green screen on my acer aspire 5315 laptop
hi, last time i had a green screen on a laptop, it was a bad connection due to wires that get damaged inside the swivel hinges, try pressing around the area of the screen and around the hinges. if the screen becomes ok then that is the fault.
jim
Feb 21, 2015 | Acer Aspire Computers & Internet
How doireplacelcdscreenoncanonpowershots51s
I would not try myself. It is likely to require very delicate connections. If you don't care about using the camera, then go ahead. If you care, see what a repair job will cost.
Jul 14, 2014 | Canon PowerShot Cameras
While using my netbook, the screen initially would fade in and out to a white screen with white lines, now fades in and out to a white screen followed by a screen with multicolored lines --this only...
It maybe that the hinges on your laptop have gone bad. The hinges house the wires that connect the video card to your display. Your problem sounds like a case of worsening hinges. Do you see looseness around the area or hear extra sounds as you're opening and closing the lid?
It could also be that your video card and / or actual LCD screen are going bad.
All of which are pricey fixes.
Hope this helped. I wouldn't buy that battery if I were you just yet.
Jul 04, 2011 | Computers & Internet
Sony DCR-SR62 screen rolls continuously
HAd the same
It's a flex wire connecting LCD with camcorder. got from the repair shop. did it by miself workes like new. it'very common in this kind of sony.
Aug 07, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
CyberHome CH-LDV 700B Portable DVD Player
you've probably over extended the the flat wirecable that powers the screen inside the dvd player by opening the screen too far. Open the dvd player as if putting in a dvd, now look in the right hand upper corner and you'll see a white flat wire, this wire is probably your problem. open the dvd player and look at the connection, the wire should be crooked, push the wire into the connection securely and the screen should come on. check it out!! Mr.Fixright.
Aug 08, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
