Question about Kodak EasyShare EX1011 Digital Picture Frame
My card has stuck inside tv, is it ok to take cover off back off tv
    Genius:
  • Kodak Master
  • 1,099 Answers
Make sure the power is off. And pls. bear in mind your warranty is gone. But other than that .... Good luck I hope you can find the card.
Posted on Oct 14, 2009
For Larrchev: trying to remove the back cover of the TV. I've removed the 4 screws outside but the cover still won't come off. Am I still missing a hidden screw inside?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations.
May 17, 2015 | RCA 20F514TD 20" TV
I removed all screws from the back of my lcd tv to replace minor part and i still cannot pry open the back cover. Seems to be stuck inside the middle.
U sure all the screws are remove.I have taken out many tvs and monitors,all way open.Recheck the middle might have some screws might miss or some covering might cover it.
Jan 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
Dvd is stuck inside the player. Can I open the dvd player to get it? It is a polaroid 32"
I removed the back cover of the tv. Then I removed the connection chord (looks like a printer cable). THere was one single bolt holding the dvd player in place. I removed that bolt and slid right to left the unit from the back of the tv. There are 9 screws that had to be removed to remove the cover. Once the cover was off it was easy to slide the two dvd's out through the normal slot. THen reveresed all actions and we were good to go.
Nov 14, 2009 | Polaroid Televison & Video
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
We cannot seem to get a Delonghi AC925CHS microwave from Argos which will work properly. We had the first one for about 3 months before all a sudden it started making a whiring sound and then the bulb went...
> silver card thing
This is the waveguide cover and it provides important protection for the magnetron.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint.
If your waveguide cover is burned, it will need to be replaced.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Microwave Ovens
Cobweb hanging inside screen
OK I DID IT I WAS AFRAID TO OPEN IT , BUT IT IS SO EASY IF YOU DO IT LIKE I DID IT , FIRST UNPLUGGED EVERYTHING WITH THE TV , TRY IT IN OPEN SPACE AND WITH LIGHT , UNSCREW ALL THE SCREWS FROM THE BLACK COVER IN THE REAR OF THE SET ONE BY ONE THE USUALLY HAVE AN ARROW MARK POINTING TO THE HOLE, INCLUIDING IN THE BOTTON OF THE COVER , ALSO UNSCREW THE OTHER SCREWS FROM THE RECTANGULAR COVER TOO THE ONE THAT HAS THE HOLES FOR THE VENTILATION OF THE POWER SUPPLY, SO AFTER THA IT IS DONE , PULL OFF THE ONE WITH THE HOLES AND THEN THE BIG BLACK COVER PULL IT FROM THE MIDDLE AND BE CAREFUL WHEN YOU DO IT BECUSE IN THE INSIDE IT HAS A MIRROR ATTACH TO IT SO BE GENTLE WHEN YOU PUT IT DOWN , ONCE IS DOWN YOU CAN FLIP IT SO YOU CAN CLEAN IT . OK NOW YOU CAN SEE THE WHOLE BACK OF THE T.V. WITH A CLEAN PAPER TOWEL YOU CLEAN IT . THEN PUT IT BACK TOGETHER USE WATER ONLY , GOOD LUCK
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Power/Switch & Heating Fault
There is a switch inside or near your timer. Take off the top back panel and look for switch. If don't see one, it's inside the timer. Spray contact cleaner inside the timer. Keever
Mar 05, 2008 | Dryers
Mintek 265D dvd stuck in drive
You need to take the back off the unit and you'll see the DVD . Take the DVD out . You may damage the DVD ( scratch it) but don't disasemble the DVD carriage or you may not get it back together. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Mintek LCD TV Progressive Scan DVD Player
Volume buttons stuck inside
hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
May 06, 2007 | Sanyo DS24425 24" TV
Kodak EasyShare EX1011 Digital Picture Frame Logo
23 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
