Question about Sharp AR-507 Copier
HP 507 PHOTOCOPIER,DISPLAYING CLOSE LEFTSIDE DOOR I TRIED CLOSING THE DOOR AND IT STILL WOULD NOT WORK. THEN TRIED OTHER DOOR FROM WORKING MACHINES IT DID NOT WORK, AND WHEN THE DOOR WAS RETURNED TO THERE ORIGINAL MACHINE THEY ALSO DISPLAY THE SAME PROBLEM.WHAT CAN IT BE?
  • kollins4ril Oct 02, 2009
    NO SOLUTION YET
  • Sharp Expert
  • 255 Answers
The door has a notch that closes the door switch , it seems that it isnt matching that area so check whether you broke it or you are not fitting the door properly or the door switch is displaced from its position.
Posted on Oct 26, 2009
  • Sharp Master
  • 1,294 Answers
See the mechanical parts,damage and chek the sensor.
Posted on Oct 03, 2009
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Dryer acts as if there is no power getting to it, but it does have 220 volts. still nothing happens when the dials are turned(timer and start dial) Start dial seems a little spongy. what should be the...
The easiest way to check the door switch if you do not have a meter is to connect the wires coming to it together. Then try it. If it work the switch is bad. All you will be doing is bypassing it so you can test. If you do have a meter, the switch is a normally open switch. When the button is pushed in, it closes making a circuit. While you have the back off. Go to http://www.partselect.com/ModelFrames.aspx?ModelID=323612&ModelNum=DBSR463EG2WW&mfgModelNum=&ManufactureID=2&Selected=00125777i04&Position=2&mfg=GE&Type=&Mark=2 and look at #507. This is most likely the problem. If it is, if your not able to check these you will want to replce #505 and #506. When #506 goes bad the dryer cycles on #505. When #505 goes bad the it cycles on #507. When #507 goes out the dryer stops all together. #507 can also be put out by the vent being clogged. Good luck.
Dec 15, 2009 | GE DBSR453EBWW Electric Dryer
After clearing paper jam, display light states back door not closed. It is closed, but I can't print
hai. you try re-start the machine, if your problem not solved, Please check the back door sensor or limitswitch.
May 24, 2009 | HP Office Equipment & Supplies
Close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
May 24, 2008 | Saeco Incanto Classic Espresso Machine
Sharp AR-507 Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
