Question about Toshiba Satellite Pro S300-EZ2501 Laptops
Dose the toshiba s300-ez2501 have blue tooth. if so it will not turn on
    President:
  • 627 Answers
This laptop has no bluetooth incorporated
Posted on Oct 02, 2009
Why windows can not find by blue tooth divice,"speaker flip2"
Is the speaker turned on? You must pair the computer with a working device.
Jun 22, 2014 | Toshiba Satellite A135-S4527 Notebook
The touchbad and the mouss can not responding completly
your best bet is to backup your data, reinstall the windows from the factory settings. if that does not fix the issue, the touchpad needs to be replaced
May 03, 2011 | Toshiba Satellite Pro S300-EZ2501 Laptops
Where can i get Satellite Pro S300-EZ2501 motherboard to buy
Hello
You can get the motherboard from your nearest Toshiba Service Center or you can buy online from HERE
Good Luck
Feb 15, 2011 | Toshiba Satellite Pro S300-EZ2501 Laptops
Does the HP DV9000 have bluetooth capability and how do you turn it on
no it dose not you need a blue-tooth adapter to connect a device to it via blue-tooth
Dec 29, 2010 | HP Pavilion dv9000z Notebook
My granddaughter pushed the F2 button while the start screen was on. how do i get out of this i keeps saying media test failure exiting PXE ROM
The F2 function on this laptop merely cycles the power plans (see link below)
http://static.compusa.com/pdf/Toshiba-Satellite-Pro-S300-Laptop-Manual.pdf
The symptom you describe is that of the OS or a boot device not being recognised. Try removing any USB dongles from the laptop if any are plugged in, eject any CDs in the tray and retry
If this does not work, as the laptop starts up, press the ( I think) F1 key and enter the Bios, see if in the BOOT screen, the hard drive and CDRom are shown. Repost your findings for more guidance
Dec 28, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
Problem with sound, modem and bluetooth for Toshiba SatelliteA100
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 13, 2009 | Toshiba Satellite A100-S2311TD Notebook
Blue tooth
you have to switch on the blue tooth of your mobile phone, switch on your laptop blue tooth also,
now open the blue tooth software on laptop there is a search option , it will detect your mobile phone and will ask for a pass key enter 1234 or any key you like but it be the same on both (laptop and mobile)
after that you send files
Oct 02, 2008 | Toshiba Computers & Internet
Bluetooth
you need to get the device introduced to each other. Turn on the bluetooth on the computer. Check Control Panel, Programs(for Toshiba Blue Tooth) or Check device manger to make sure the blue tooth is not disabled. Check the manual that came with your phone. You will need to put them in find mode and they should find each other. Here is the Toshibe site and booth info: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=1209152&ct=RG&soid=1328782&BV_SessionID=@@@@0630805741.1171140917@@@@&BV_EngineID=ccciaddkedlmlgicgfkceghdgngdgmn.0 Good Luck, Tim
Feb 09, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Satellite Pro S300-EZ2501 Laptops Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
