Question about Spidem Divina De Luxe Digital
Spidem Divina Power Problem
I have metered out the appliance, it appears that there is power getting to the control boards and all other locations within the machine. I am unable to determine why, after plugging in the machine the controls do not light up and I am unable to operate the machine.
    Sergeant:
  • Spidem Expert
  • 223 Answers
If there is power at the board and no response at all than it has to be your board that has burnt out. Also, make sure that the temp sensor coming from the boiler is plugged in. The temp sensor is the only thing that would prevent it from coming on and that very rarely happens.
If you need this part, it will have to be ordered.
You can contact us at http://cerinicoffee.com/contact-info.asp
Espresso Machine parts and Cleaning Supplies
www.CeriniCoffee.com
Posted on Dec 21, 2007
How to check door switch for being bad
Hello Don;
My name is Peter. I am a retired field service appliance technician.
You need to purchase a multi-meter. This is a tool that will save you a lot of money in your self repair off all of your appliances. They Cost $20-25.00.
The two primary reasons your dishwasher may not start is your Bi-Metl thermal fuse and the door switch.
1.) Bi-Metl Thermal Fuse:
This is a thermal safety device that installs in the console. When the temperature inside the dishwasher gets too high, the bi-metal fuse burns out and breaks the circuit that allows electricity to flow to and from the main electric control board.
Substitution Part Number: W10258275 - Cost: $25.00
It is located next to your control board. Caution: Before touching you control board ground your self by rubbing your hands on bare metal. Static electricity will knock out a board.
a.) Turn power off at the breaker box.
b.) Disassembly the control panel to access the thermal fuse.
c.) Disconnect the two leads from the thermal fuse.
d.) With your multi-meter set on the lowest Ohms (Omega Symbol), put one meter lead on each contact.
e.) If your get a reading other than, '0' then the thermal fuse is bad.
2.) Door Switch:
This is located in you door handle assembly.
a.) Lift the switch off the two retaining pins.
b.) Disconnect the two contact wires.
c.) Using your multi-meter the same as above - hold the switch button in with the two meter leads on each contact. Here, you also are looking for '0' Ohms if the contact switch is good.
Dec 29, 2014 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Divina deluxe
You should have screws at the top to remove. Unplug it first. Then when you have the top removed, you can begin your cleaning. Put screws back in place and you are ready to go.
Feb 02, 2013 | Spidem Divina De Luxe Espresso & Coffee...
My Saeco spidum divina leaks water from the bottom. The water is clear and warm and I can still make coffee. What is the problem?
Could be a leak in the high pressure lines or the boiler. The boiler leaking was a issue on the order models by saeco.
Here is a link the boiler that is most likely in your machine. 2 element boiler
May 07, 2011 | Saeco Spidem Divina Deluxe Fully Automatic...
How to change language on my coffee machiner
Try to enter in the programming mode, check your manual and see if you can find a Language item or something:
• Ensure that the ON/OFF switch of the appliance is switched to "O" and that the hot water knob is OFF.
• Press the buttons (23) and (25) and (see the back of the machine or the manual), at the same time, switch ON the appliance using the ON/OFF switch .
Mar 15, 2011 | Spidem Divina De Luxe Espresso & Coffee...
How to operate Spidem divina automatica deluxe.
hi, scuse me but i thing you will have more chance if you aske your question in the problem section
Nov 12, 2009 | Coffee Makers & Espresso Machines
Spidem Divina - one cup and 2 cup lights flash together
Hi
Caution light usually means something is out of place. Nothing will work until everything is in place and locked.
Steady water light means it needs to be primed, (run water by opening the steam knob). It won't heat until the boilers are primed.
Jun 19, 2009 | Saeco Spidem Divina Deluxe Fully Automatic...
Spidem divina deluxe digital
I think the gear wheel in the machine is broken and have to be replaced.
Jan 04, 2008 | Spidem Divina De Luxe Digital
Spidem Divina De Luxe Digital Logo
4,768 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Michael Galve
Michael Galve
Mike
Mike
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
