WOULD LIKE TO INSTALL 2ND OS(98) ON SYSTEM THAT HAS VISTA AS OS
    President:
  • 627 Answers
You cannot install Windows 98 on a system which has a better version of operating system.
You have to install Win98 first, to 1 partition which is formatted under FAT32 and on the 2-nd partition you can install Vista.
Posted on Oct 02, 2009
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Tip
I need Postscript drivers for Lexmark printer T630.
Hi.
This printer supports Postscript, PPDS, and PDF emulation only on systems up to Windows 2000, on Mac OS X up to 10.6, and on Solaris.
Windows 7and Vista are not fully compatible with this printer, and the printer will not have full functionalities on this systems.
If you have Win XP, Win dows Server 2003, Win 98, Win 2000 or Mac OS, then all you have got to do is installing full factory driver software.
If you have Windows 7 or Vista, then you should upgrade the printer to get full features. Lexmark has opted for not updating this printer software. Full software release for Windows Vista and Windows 7 does not exist.
The drivers and software for this printer can be downloaded from Lexmark website, using the links below:
Lexmark_AAG_WinXP_PS_Driver- Post script driver.
System PCL Driver for Microsoft Windows XP and Server 2003
System PCL Driver for Microsoft Windows 2000.
PCL6 driver for Microsoft Windows 95, 98 and Me.
Printing solution for Mac OS X v.10.6.
Print driver for Sun Solaris 10 x86 systems.
Network print support for Linux.
Here the full driver installation procedure : How to install a Lexmark printer without the driver and software disk.
The printer may still work on Vista and Windows 7 using the built in drivers, but it will have limited functionality. See: Windows 7 Information.
Regards.
on Mar 24, 2010 | Lexmark T630 Laser Printer
I need a disc to install my lexmark x1180 printer to a new computer.
You need to download Drivers for your Lexmark X1180 Printer to install it on new computer.
You can download these drivers from here according to your Operating System :
If you are having trouble with these links then you can try Drivers Collection @ driverscollection.com/?H=X1180&By=Lexmark or Silicon Guide as well.
Aug 11, 2011 | Computers & Internet
Hello sir, im trying to make a multiple operating systems from CD/DVD. how can i do. solve this
Install 1st operating system like XP.then install 2nd OS on that like Vista and install these two in different partitions. This will make your computer dual boot.
Mar 29, 2010 | Microsoft Windows Vista Home Premium with...
How can i install on windows xp
Yes, you need the driver for windows XP. go to here
May 30, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Bjc2100 install disk won't work on my laptop. I use Windows Vista system.
The BJC2100 install disk came out when Windows 98 was in its heyday. It will not work in Windows Vista. The Windows Vista OS already has a driver imbedded that will work with your BJC-2100. It "should" recognize the printer and automatically install the driver. If it doesn't, try the "Add Printer" feature, select Canon as the manufacturer, and look for the BJC-2100 Series driver.
Dec 10, 2008 | Canon Office Equipment & Supplies
Operating system cannot support lex Z2300 series printer...install cannot continue. Win. 98 system.
It simply means that your printer is not compatible with your os in its present form. I'm guessing XP or Vista? Anyway, there should be patches available at your manufacturers website. Look for the drivers/downloads. Also check the xp and vista compatbility lists.
anaanymous
Oct 11, 2008 | Lexmark Z2300 InkJet Printer
Help me
It is a pretty simple process
Create 3 partitions on the HDD (Vista requires 20 GB minimum)
Install XP on 1st, Vista on 2nd, Linux on 3rd
You'll choose the partition to install on during the install process of each OS, you can create the partitions during the XP install
Jun 08, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
