Hitachi rear projection tv. screen looks green
What would cause my picture to have too much green?
  • kevdol Mar 24, 2008
    I had the same problem and fudged with those controls and was also able to resolve it. Thanks!
    Genius:
  • 1,694 Answers
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Posted on Dec 21, 2007
4 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: hitachi 60" sb red and green 3d looking screen at top and bottom
Hello justright197,
I posted this in an eariler solution and there are numerous references to this type of problem on fixya.com, however it fits in this case, so here it is:
This denotes a convergence problem. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply heat sink paste to the STKs when attaching them to the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Shuttle83
Posted on Feb 25, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi rear projection tv. picture is shadowy/3D
This set uses two convergence chips--both need to be replaced and the set adjusted----If you know how to do good soldering I can tell you where to look and what usually needs to be replaced---Parts cost should be less than 20 dollars if you buy the parts on Ebay---
Most shops charge 300 or more for this type of repair---I just returned home from a set with this type of problem---in home total repair 250 total---If you cannot do the repair I suggest you shop around and find someone who can do it in your home---any good repair person can do this in about 1 hour---I am getting ready right now to do another one near where I live.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE FEEL FREE TO ASK ME...I am here to help people.
REGARDS, SD TECH
Posted on Oct 05, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
Hitachi 51'' rear projection convergence chip problem
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Hitachi 51F500 51" Rear Projection...
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
RED WAVY LINE THROUGH SCREEN OF HITACHI 57F500 REAR PROJECTION HDTV TV
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 02, 2009 | Hitachi 57F500 57" Rear Projection...
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
Red Alignment problem on a Hitachi 51inch rear projection tv
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi S57500 projection tv turns itself off
Hi, I`m afraid it`s not good news, you have a bad green picture tube, video-tek
Feb 10, 2009 | Hitachi 57S500 57" Rear Projection...
Hitachi 57UWX20B 57 in.
*Screen Looks 3-D
*Colors wont align
Sep 08, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Green picture and distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Mar 11, 2008 | Hitachi 42V710 42" Rear Projection HDTV
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
791 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
