Question about Xerox C2424 Copier
Error code-07,010.43:19044 I'am a Tech, and I got this code when testing a machine?
    Problem Solver:
  • 6 Answers
07,010 Errors on a C2424 are the same as on the 8400 series, the printhead tilt mechanism is obstructed or incorrectly timed. Check the silver square block on the left of the printhead for spilt or leaking wax, also check the 2 cams that lift the oil roller up to the drum, if they're cracked and out of line they stop the tilt drive mechanism from functioning
Posted on Oct 29, 2009
  • 239 Answers
I am a tech also. This sounds like a paper path code.
On some of these machines the motor drives all feed rolls on all trays. Some have independent motors for each tray.
If you are using one tray check to see if that motor is working. Sometimes they will just momentary start then shut off. This could be a bad motor PWB or a main board problem.
Actuators on these sensors will hang up. Check the actuators to see if they are operating. If you can swap a tray sensor with another see if this changes when feeding paper. One sensor might be not working right.
Check the doors to see if they are closing right. The drive rolls might be not be holding on the paper causing stalls and constand paper jams.
Check to see if the rolls are binding. They appear to be fine until you spin the rollers, they should spin free.
Good luck.
Posted on Oct 16, 2009
What is an F3 26 error?
Appliance tech has a computer program or hand held device that has the answer. Newer machines are built to that spec. F3 shows where the main component of the error exists. #26 may not be a commonly occurring error. Go to Google and type in F3-26 or something similar. See what happens. Failing that contact a repair Company or your trusted Tech.
Jun 28, 2014 | Samsung WF337AA Front Load Washer
Code fault E50
Need to put into self diagnostic mode and test the components. You can find the tech repair sheet in the machines that will tell you both what the error code is, how to test it, and how to replace it.
Dec 21, 2013 | AEG T57800 Electric Dryer
Affinity front loading washer error e56, what does this mean?
1) Read the owner manual and proceed section troubleshooting,this mean the motor, probably is defective and need replace.
2) Try to run the software diagnostic.and make the test 9 for solution or diagnostic.
3) or call some tech from company or another you know it
God bless you
Sep 26, 2012 | Frigidaire Washing Machines
What does error code 5D mean for Amana NFw 7200tw? I have had more problems with this machine.
Look under the top or inside the lower service panel and you will find a tech sheet that will explain the code and how to do testing and diagnosis.
Mar 21, 2010 | Washing Machines
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Sep 25, 2009 | Electrolux EIED55H Dryer
Our washer's lights are blinking and nothing is happening? It won't start.
I don't have your specific solution, but I found a lot of manuals for this model washer here:
http://youserguide.org/wiki/Frigidaire_ATF6000E
The one marked wiring diagram is actually a "Washer Tech Data Sheet" that has "Diagnostic tests" quick checks, an error code list, and more importantly, how to read the error codes and the tests to run after getting the error codes. Hope it helps.
Aug 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite HE5t Washer Error Code F11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Jan 03, 2009 | Washing Machines
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Xerox C2424 Copier Logo
121 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
