Question about Maytag MAV7600 Top Load Washer
Wont complete final spin and drain
Our top load washer will not finish the final spin nor drain. You then have to move the dial around to another spin cycle. It will then drain and complete the final spin. A repairman came out tonight and seemed bewildered. He replaced the belt but after he left, I ran a load and we still have the original issue? Any thoughts I can throw at him to help us solve this problem?
  • charbuild Dec 30, 2007
    having the same problem. Timer advances to stop but does not pump or spin. I can move timer all the way around and back to spin and it finishes, Wife also states that machine sometimes doesn't remove all soap and clothes smell. Don't know if the two are related.Thanks
    Sergeant:
    Champion:
  • 262 Answers
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Posted on Dec 21, 2007
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Washer cycle not starting
Did you read the user manual of your whasher? Unplug the washer to the wall out let and then verify carefully whats going on. maybe some unwanted material in it..check all the necessary components and test again.
notify me for what did you notice. melnavz
Apr 09, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Samsung vrt washer not draining
I've had so much issue with this washer since I've own it and it hasn't even been a year..I just finished fixing the same issue you have with your washer. I had to drain the washer which you were right very messy. My problem was one of the wire came lose. Of course it was from the water pump that was attached to the tub...Who would design something like that.
May 20, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer does not drain or spin after rinse cycle is done.
Sounds like one of the contacts in you programmer is worn out or broken. That means a new programmer.
May 20, 2009 | Crosley CAWC529JQ Top Load Washer
Won't spin out on normal wash cycle
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Mar 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Maytag MAV7600 Top Load Washer Logo
224 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
