Question about Zebra Eltron P420C Printer
The Zebra P420C printer was working fine then it would not print any cards. The unit was cleaned and a print head replaced the unit will still not print any solutions. SN611182 (newer style)
  • hfd130 Oct 02, 2009
    This doesn't explain why it would not even print a card from the printer test screen.
    President:
  • 1,129 Answers
Try going into the hardware install/removal wizard or into device manager to remove and reinstall the driver for the unit this may help.
Posted on Oct 02, 2009
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at www.DiscountIDStore.com
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Controlador de impresora zebra modelo p420c
Saludos. Conseguiste el driver para windows 7?
Jan 07, 2011 | Zebra Eltron P420C Printer
My printer makes a very thin stripe in the print on all cards, it looks like a dust-particle problem, but the print head seems to be clean, can there be something else?
Looks like you may have a dust particle on your print head. Try cleaning it with a cleaning card. If it does not go away, it may be that your print head is slightly damaged, which means you will have to change the print head.
Mar 09, 2010 | Zebra Eltron P310I Thermal Card Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
Clean prinnter massage
The Zebra printer displays the Clean Printer message when the printer prints a 1000 cards.
This is to maintain printer and ensure good print quality.
The way to clear the message is to get cleaning cards and run a cleaning routine.
The CD that comes with the printer will run a video showing how to run the cleaning cards through the printer. Printer needs 2 unique cleaning cards (1 short & 1 Long)
Feb 01, 2009 | Zebra P330i Thermal Card Printer
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
ZEBRA P33Oi "WAIT TEMPERATURE"
Have you cleaned the printhead yet? If it is easy to get to. Use some alcohol and cotton cloth.
Aug 09, 2007 | Zebra Eltron P330i Card Printer
Zebra Eltron P420C Printer Logo
188 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
