Question about Roper RT21AKXKQ Top Freezer Refrigerator
The overload on the compressor keeps kicking out and back in.
  • milten1
    milten1 May 11, 2010
    its more than likely just a bad
    overload, you can try to replace it, but if the same thing happens right away, well then its your compressor,,, 8 bucks to fix or know
    much better than a repair guy telling you after you write him a check
  • Johnny
    Johnny May 11, 2010
    whats the make and model
    Sergeant:
  • 272 Answers
I would replace the relay assembly..this is most likely the problem..its possible the compressor is defective and if the relay does not start the compressor..you most likely have defective one.
Bruce
Posted on Oct 05, 2009
Model# 253.61821014 compressor keeps kicking off
Feel the top of the compressor is it hot? Usually when a compressor will start and stop this is called short cycling and it is caused by a defective start relay, overload and capacitor. Sometimes it it cause by a defective fan which when this happens all parts including a new fan must be replaced
241941004 Start Relay
218909913 Run Capacitor and a
242018301 Condenser Fan Motor
APPLIANCE911
It is not stuck in defrost mode with those symptoms
Apr 30, 2016 | Kenmore Refrigerators
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Not cooling or freezing
Do you hear the compressor kick on, or try to kick on?If not, unplug the unit, remove the "overload relay" from the compressor and give it a shake. If it rattles, it is burnt out and needs to be replaced. Here is the new part.
If the "overload relay" is good, check to see if the "defrost timer" is stuck in the defrost mode. You can take a flat-head screwdriver and turn the timer til it clicks and it should start the compressor.
Keep me posted!
Oct 19, 2012 | Maytag MBB2256G Bottom Freezer...
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Freezer won't kick on
That is the overload protector on the compressor. Keep the door closed to preserve the cooling you have from the frozen food. Leave it unplugged for about an hour. Bang on the compressor with a rubber or wooden hammer then plug it back in. If it does not start you either need a new start relay or a compressor.
Apr 15, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
My copressor won't start. relay works fine in
HAVE YOU TRY A 3-N-1 COMPRESSOR BOOSTER|? YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE THEM. TELL THEM THE SIZE OF YOUR FRIDGE AND COMPRESSOR AND THEY SHOULD BE ABLE GIVE YOU THE RIGHT ONE. FOLLOW THE INSTRUCTIONS ON THE 3-N-1 AND CONNECT TO THE COMPRESSORS. BUT CONNECT THE TWO BLACK WIRES TO A EXTERNAL POWER(GET AN EXTENSION CORD AND CUT IT, WIRE NUT THE TWO WIRES TOGETHER). PLUG IT IN, IF THE COMPRESSOR KICKS OFF, YOU HAVE A BAD COMPRESSOR. IF IT RUNS WITHOUT KICKING OFF, THAT MEANS YOU ARE NOT GETTING POWER TO THE OVERLOAD RELAY TO TURN KICK ON COMPRESSOR. CHECK YOUR TEMP CONTROL INSIDE FRIDGE, AND THE DEFROST TIMER(MIGHT BE STUCK IN DEFROST)
Jan 24, 2010 | Amana Freezers
I have a 13500 Dometic roof mounted ducted AC on my motorhome. I have changed the Board twice and the thermostat once and the same problem occures. When you first put the AC on it works fine until it goes...
May need start capacitor and relay (called start kit) or some of the compressors have a thermal overload under the compressor cap. If it's a thermal overload, it has a bimetal disc and when it reaches a set temperature (hot) the disc will warp opening the compressor circuit and not allowing the compressor to come on till it has cooled down. if this is the case then the compressor is not getting enough refrigerant back to it to keep it cool or it's drawing high amps.
Feb 24, 2009 | Heating & Cooling
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Roper RT21AKXKQ Top Freezer Refrigerator Logo
146 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
