Question about Garden
Drive belt diagram for wheel horse b-115 - Garden
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    model number from the ID tag please transmission or mower deck belt?
4 Suggested Answers
SOURCE: need a belt routing diagram for wheel horse raider
have a raider 10 in gravenhurst with a deck sticker that shows the belt routing......if you still need the diagram, let me know
Posted on Jul 29, 2010
  • 376 Answers
SOURCE: belts coming off lawn mower troy built 46" 21hp horse 14at809h766
Go to... http://www.managemyhome.com/mmh/owner_manuals and enter your model # that under the seat.
Posted on May 25, 2009
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
Diagram for 25 horse 54 inch drive belt for husquvarna
PDF]OM, LGT 2554, 96043006100, 2008-12, Ride Mower
www.husqvarna.com/.../HUSO2008_USen_O0802072...
Husqvarna GroupLGT2554. Owner's Manual / 96043006100 / 2008-12. 03002 ..... mower blade drive belts in the Service and Adjustments sec tion of this manual. Verify that the .
Aug 25, 2015 | Garden
I have a wheel horse 1973 10 8 speed and I need a wiring diagram
Do I understand correctly that you need the wiring diagram of a WHEEL HORSE? I don't want to be rude and delete this question MABBE YOU COULD EXPLAIN BETTER the issue
May 29, 2015 | Cars & Trucks
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
Need a manual for Wheel Horse 520-HC!
https://lookup3.toro.com/request/request.cfm Go to this website and put in model number and you can download a manual and parts book.
May 31, 2012 | Garden
Jul 18, 2010 | Toro Garden
Need a belt routing diagram for wheel horse raider 10 lawn tractor
Jul 14, 2010 | Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,079 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
