Question about Pyramid - PS21KX 20 Amp Power Supply Car Audio Amplifier
PS36K power supply overload problem
I have a PS-36K Pyramid poewr supply. When I turn it on it goes to 15 volts and the protection light comes on and the unit beeps. I cannot adjust voltage. I need a schematic and would appreciate any suggestions you can give. THANKS!
Jim Goldring
  • 1 more comment
  • Anonymous Jan 28, 2008
    I have the same problem.When I hook anything up,even a small clearance light bulb,the voltage drops to zero and the protection light comes on.
  • Anonymous Sep 17, 2008
    Yes. I currently have a PS21KX which has a similar outcome. The volt indicator is +/- 15v, L.E.D flashes, and there is an audible alarm/beep. But the user manual points to a high current drive of 90% of max/limit output. Is the 723 still a factor? Thanks.
    JR-TTI
  • William Hamm Jan 13, 2009
    I have a PS 36 kk supply and the buzzer is on constantly and voltage is 15 volts and will not adjust. Whats wrong? Bill
  • 631 Answers
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Posted on Dec 21, 2007
Hi,We have a Pyramid Gold Series PS-26k that won't
try changing the battery out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Computers & Internet
Pyramid PS-21K Power Supply HELP!
check the resistors that bias the transistors, and also any zeners connected to them.
Dec 30, 2008 | Pyramid 10 AMP 13.8V POWER SUPPLY Car...
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Nov 15, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid ps-21k power supply
you need to get the voltage regulator circuit checked in your ps-21k
Jun 13, 2008 | Pyramid 10 AMP 13.8V POWER SUPPLY Car...
Pryamid ps36k power supply
Have you done any troubleshooting at this point?
Are you going to try to repair this yourself?
Have you tried to locate a schematic for the supply?
Mar 11, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid - PS21KX 20 Amp Powersupply overload
The problem I have had with a PS-20 is a blown capacitor. Hooked to a radio, would allow radio to receive fine, but when trying to transmit, amperage would bottom out. Behind the transformer is a large circuit board. UNPLUG POWER SUPPLY, remove cover, Undo the two nuts, flip board over, and gently rock the 4700uf capacitors side to side. If they move more than 1/16th of an inch, chances are they are blown. Remove/replace and should be good to go...
Jan 10, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid - PS21KX  20 Amp Power Supply Car Audio Amplifier Logo
1,197 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Frank Mangiapane
Level 1 Expert
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
