Computers & Internet Logo
Posted on Oct 02, 2009
I tryed to turn on my windows update but it wont work i tryed run-supportMSC and turn it on that way and when i gat into propertys it will not let use the run with 98 ect. is there any softwar i can download fron microsoft downloads. i am using dell dimension xp please help thank you
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Oct 02, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
5736
Points
69
This problem will not be easily solved....try if you can to backup all your files and re-install the windows program...this may sound a strong reply but re-installing has overcove hundreds of problems
This product doesn't work with the Windows Vista version. They're is a ddriver problem . No version of the drivers for vista turn on my pc!!
In windows you can find the program you want to run and then tell windows to emulate a previous version. If you are working within VISTA then you right click the actual program ICON (NOt a shortcut on desktop) and choose properties you wll see a tab called COMPATIBILITY. In the top you will RUN THIS PROGRAM IN COMPATIBILITY MODE FOR ######## here you can choose a previous version of Windows such as XP or earlier to use. Try having the program run in compatibility mode to determine if it can find the Sound Card. Its possible a driver update or other Windows update in VISTA is incompatible with the device.
HI, my aut.update for windows vista pro is not working. When I try to download it says "cannot download updates". My computer watch is running ok. I have also tried to update all my drivers, it is also...
Turn the security software off and check.
2. force the global DNS server - network connections- lan - tcp.ip propertys - advanced. underprefered dns enter - 4.2.2.1 and alternate dns enter : 4.2.2.2 .
3. try with new use acconut .
2helpful
2answers
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Eveytime I try to cick the icon to get into the contol panel
go to run dialog and type services.msc and select the Automatic Updates (Windows XP) and right click and select the start option.
In Vista got to services.msc and start the windows update service.
After starting the service select the same service and Right clich on that service and select properties in general tab select the startup type as automatic. and click ok on properties dialog.
1helpful
Cant Install and run DK My First Dictionary
I had the same problem installing this on my PC running XP and finally found the answer was installing an XP update SP 1 .exe from this site http://support.selectsoft.com/products/M/LDMYFAMD2J.htm Hope this helps. [email protected]
Generic host win32 services problem
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the above patch solution and the following windows update solution works only on PC/computer running genuine Windows and not pirated versions):
  • Go to the start menu
  • Right click “My computer”
  • Click “properties” then the “automatic updates” tab
  • Choose “turn off automatic updates”
  • Restart your computer
  • Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
  • Manually update windows
  • Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
  • Go to Run and type regedit
  • Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> Browser >> Parameter
  • look for the key IsDomainMaster
  • Set its value to False
  • Restart the computer
2answers
Trying to install new game. noticed that the box says nothing about windows vista does that mean this wont work on my computer?
HI-
Yes, chances are you can't install it on a windows vista Operating system, suggesting to check website of the game and look for updates if there are any that will make it run with vista. look for a patch or update for it.
Hope this helps
2answers
Keep gatting error code 80073715 on windows update!
You can try the following and it should clear it up.
Rename the SoftwareDistribution folder in C:windows (it will be recreated next time you visit Windows Update again)
You will lose your history but that's not important.
If the above step doesnt clear it up continue below:
Click Start, Choose Run.
In the Run box, type services.msc.
Click OK.
Right-click the Automatic Updates service. ( with Vista it may read Windows
Update)
Click Stop.
Stopping the service will take a moment.
Rename the "SoftwareDistribution" folder:
a. Click Start, click Run, type %systemroot%, and then click OK.
b. Right-click the SoftwareDistribution folder, and then click Rename.
c. Type SoftwareDistribution.old, and then press ENTER to rename this folder.
Click Start. Choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
Retry Windows Update before reading further.
If you need to reinstall the ActiveX controls (because they may have become
corrupt):-
Follow this article (the article is listed the download for the old client) -
The Windows Update Web site and the Microsoft Update Web site do not scan
for updates when
you repair a failed installation of Windows XP Service Pack 2 or of Windows
XP Service
Pack 1
http://support.microsoft.com/kb/916259
Note: WU Client 3.0 - Windows Update Agent
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe
Thanks
E260 Wont Turn On
on the desktop click right button and click properties.now go to the apperance below the windows and buttons chane it as windowsxp style.
R40 Thinkpad will not run on battery power after update
try uninstalling the update in the add/remove programs
or turn off windows power management
your choice.
in control panel
in bios
and in windows display properties/advanced
Grand Canyon Tech
Grand Canyon Tech
