Question about Garden
Weed trimmer won't run while choke is off.
Replaced fuel lines but not sure if i did it correctly. It is a 3 line system and I have the larger line with filter coming out of tank to bottom of carb. smaller line from tank to bottom nipple of primer bulb and the third connects the top nipple of primer bulb and the top of carb. When i start it, it'll run for a little bit in half choke but when I turn the choke off it dies even if i have the throttle pushed down. Any help would be greatly appreciated.
  • Bruce Canfield
    Bruce Canfield May 11, 2010
    It sounds to me like you have the fuel lines hooked up correctly. Is the primer bulb pumping fuel and can you see fuel in the lines going to the carburator? Was the trimmer working properly before you changed the fuel lines? Is the screen clear of carbon build-up at the exhaust port? Please provide some additional info. Thanks.
5 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
rycgl
  • 1545 Answers
SOURCE: I bought a Poulan PPB100
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Please vote on this solution.
Posted on Sep 01, 2010
  • 1746 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
  • 32 Answers
SOURCE: Hi, My weed wacker will only run on full choke.
Look on the carb for 2 screws side by side. where those screws go into the carb, it will be stamped with an "H" and "L". Open the screw that is next to the "H", counterclockwise about 1/4 turn at a time with the engine running, that should solve it.
Posted on Sep 20, 2011
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
I have a ryobi weed wasp line trimmer, it's a few years old maybe 12 years, the other month I left the machine out in the rain over night, and now after numourus intermittent tries over severel weeks...
sounds like the carb is gummed up. take the carb off and take it apart. pull the needle out and make sure it slides freely, if that doesnt fix it there probabbly an air leak in one of the fuel lines or the prime ball.
Jul 09, 2011 | Refrigerators
Jun 13, 2011 | Craftsman Garden
Have a poulan pro ppb350 31ccweed eater runs short time. put a carb kit in carb engine runs a short time.then dies.not sure if fuel lines are in correct place on carb?
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the fuel tank.
Sep 11, 2010 | Poulan Garden
I bought a Poulan PPB100 at a yard sale for $20.00. I got it home and got it started and running but it leaked gas like no tomorrow. I took it apart to see what was needed and found that all the fuel...
Aug 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing fuel lines on ryobi weed eater,need
Jul 10, 2010 | Craftsman Garden
My trimmer works only with 1/2 choke, start right up but won't work for long and not working on idle. new sparkplug and everything clean.
There can many different answers. Fuel was old? Could have junked up the fuel filter in the fuel tank $5 or fuel junked up carburetor kit will cost you $15 take in carburetor to lawn mower shop. If you do rebuild make sure to blow out all ports and lines with compressed air. Make sure to run weed eater out of fuel if stored for the winter. M.J.'s Mobile Maintenance
May 22, 2010 | Husqvarna 28cc Gas Line Trimmer
Poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Sep 20, 2009 | Garden
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
