Question about Maytag Neptune MDE5500AY Electric Dryer
Won't start. Light are lit, but the 'start' button does nothing.
  • mikewson Oct 05, 2009
    Thank you. We will try it.
  • 40 Answers
If the display shows an '88' then place a heating pad over the display. In a few minutes the '88' code will clear, and the dryer will work. Sounds crazy, but it works for me every time.
Posted on Oct 03, 2009
  • daveg4christ
    daveg4christ Jan 22, 2013
    Used a hair dryer and it totally worked! Thanks for the advice about heating up the front of the control board!
Disherwasher will not start
Are you sure it is the Dry light that is lit, or is it the little Lock symbol located ABOVE the Dry button that is lit? If it's the latter, you can turn off that light (turn off the control lock) by pressing and holding the Dry light for 4 or 5 seconds until that light goes off.
Aug 04, 2014 | Frigidaire Dishwashers
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Won't start
Check alternator fuse , it's should be a high amp fuse . Question is did you give some one a jumb start , this could happen , another thing to check is your ignition fuse and your ignition switch , but first check all fuses . Including the big once under the hood and inside the car . Good luck and I hope this helps
Jan 15, 2013 | Cars & Trucks
Maytag mdb7749awb1 won't start
Thank you very much after doing the normal heated dry three times all the lights on the panel lit up and my dishwasher started running
Aug 18, 2012 | Dishwashers
Help please...my Dell desktop Inspiron 518 won't turn on at all.
First Option:Please Take a New Window .
Secon Option:This Falut is Hard.
Last Option:This Falut is Your Board The Board Is Shatig.
Jul 30, 2012 | Dell Computers & Internet
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
382 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
