Rca model hd52w59 stays on for a few min then turns off will turn dack on after a few min some time does not do it at all
  • rdobson Oct 02, 2009
    do you know rca part #s by any chance
  • 5,138 Answers
Replace capacitors cp150-2200uf 16 use25v cp114 and cp120---220uf 35v resolder all pinns on FBT flyback transfomer.
Posted on Oct 02, 2009
  • ladywinn
    ladywinn Oct 03, 2009
    Capacitors are located on deflection board bottom board onleft side look up to front of board that is where the caps are Call Mats for Parts and supplys 1-800-628-1118
My 52" RCA projection, model
comon fault is one of the picture projection tubes is broken.not worth fixing
Mar 29, 2011 | RCA HD52W59 HDTV Projection Television
My RCA HD52w59 turns off and on while im watching tv this happens atleast 4 to 5 times an hour
the deflection board is going into shutdown. You can get a replacement deflection board for your model at www.tvrepairworld.com
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
Picture on our RCA model#HD52W59
This is probably cold solder joints on the IFT. It's an easy fix for a tech. Take care of it now so major problems don't incur.
Dec 10, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA hd52w59. I just replaced fl231,
find your 'service' page, usually you have to hold the input button and the power button together for a couple sec. a new menu should appear Look for the factory restore choice and choose it.
Apr 22, 2009 | RCA HD52W59 HDTV Projection Television
Won't turn on-flashes 3 times.
Flyback and or CP150 are the most likely two components to cause that symptom. If you need more info let me know and also post the chassis number off the rear tag as that model used both ITC and ATC chassis numbers.
Mar 13, 2009 | RCA HD52W59 HDTV Projection Television
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
RCA HD52W59
that model has been known foe having bad flybacks. more than likely the flyback needs replacing especially since you noticed a smell when it went out
May 25, 2008 | Televison & Video
Rca hd52w59
does the power indicator light up? Does it blink 3 times then go off/ let me know and I may be able to help you that model is famous for bad flybacks
Apr 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 color goes green then black screen
This set has flyback problems. you would need to check a few things to make sure. What about RP020 is this open? Check also RP231 and IP190. Check make sure all cables are seated properly too. For more info visit ctechnicians.com
Jan 03, 2008 | RCA HD52W59 HDTV Projection Television
My RCA HDTV
see if your model has a convergence option on the menu under the setup.....mine does not so i had to pay to have mine repaired and now, a week later, the problem has returned.
Aug 31, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
