Question about Russell Hobbs RH-SC600 6-Quart
Says low high and auto shift what does auto shift mean
  • maureen880 Oct 03, 2009
    i have worked it out myelf but thank you any way regards maureen
  • jlh4652 May 11, 2010
    yes those are the settings I never got a manual so..?
Wat dose auto mean on my slow cooker
On Auto setting, the cooker is on high for an hour and then goes on low heat for the rest of the time.
Feb 03, 2016 | Crock Pots & Slow Cookers
What is the auto switch on a small crock pot for?
That is so that the crock pot goes on high heat to get things heated up faster and then shifts automatically to low after it is hot...so that it does not over cook your food when left for a whole day...
heatman101
Jan 12, 2011 | Rival Crock Pots & Slow Cookers
On the crock pot it has low, high and auto What does auto mean?
Hi, well, Auto means that it uses an internal, weight & temperature sensor to determine the Cooking time of whatever is in it. It will then "Cook" until "It" thinks it is "Done" and turn off at the end.
I believe that they are NOT that accurate? But a possible time saver nevertheless.
Aug 19, 2010 | CorningWare Crock Pots & Slow Cookers
No manual for my old Crock Watcher by Proctor Silex
The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
Oct 19, 2009 | Crock Pots & Slow Cookers
Tower slow coocker switch setings auto high low what do they mean
low runs around 225
high about 275 some models go as high as 300
auto it will cycle between high and low depending on moisture content
Oct 08, 2009 | Crock Pots & Slow Cookers
Auto/shift button on a crock pot.
it does just what it says . its a great feature . in auto shift mode the pot will be on high untill it reaches full boil or a pre set time has gone by .... most people start there crock pots on high and turn them to low when it gets cooking .....this does it for you ... happy crock poting ...Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 08, 2009 | Hamilton Beach Proctor-Silex 32190...
MANUAL
please rate if this helps fixya problem
respond with any other questions...thanks
Jan 14, 2009 | Hamilton Beach 33015
Older model General Electric crock pot
The auto button is ususally it startts off on high setting to warm up the crock and when it reaches a pre set temperature it will shift to med or low which ever is the next lower setting it will continue cooking at this setting unless you change it
Dec 31, 2007 | Crock Pots & Slow Cookers
On my durabrand slow cooker
The auto mode means that the cooker will start off at high and then will switch to low after an alloted amount of time.
Nov 17, 2007 | Select Brands SC-25 2.5-Quart
Russell Hobbs RH-SC600 6-Quart Logo
204 people viewed this question
Top Russell Hobbs Crock Pots & Slow Cookers Experts
Tally Girl
Tally Girl
Jack Frost
Tom Chichester
Are you a Russell Hobbs Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
