Question about Fuji FinePix F45FD Digital Camera
Frame no. full - Fuji FinePix F45FD Digital Camera
  • 244 Answers
Read the solution on my tips n tricks page on my profile under "THE ONLY WAY I KNOW HOW"
Thanks
Posted on Oct 02, 2009
Testimonial: "quick response and the person knows his/her stuff. Fix worked and camera is a go. Thanks"
Frame no. full
In the English Manual on page 150 it says Frame no. full:
The frame number has reached 999-9999. Remedy:
1 insert a formatted Memory Card into the camera. 2 Set RENEW as the FRAME NO. setting in the (SET) SET-UP menu (> p.117).
3 Start taking pictures (The frame number starts from "100-0001").
4 Set CONTINUOUS as the FRAME NO. setting in the (SET) SET-UP menu. Good luck
Jan 13, 2014 | Fuji FinePix S700 Digital Camera
After taking pictures on a full screen, suddenly my camera appears to be set showing a black frame below/above for horizontal, left/right for vertical. I can no longer return to the full screen... wh
You've apparently switched your camera to the widescreen mode. To switch to another mode, follow the instructions under "Changing the Recording Pixels (Image Size)" on page 65 of this manual.
Mar 23, 2013 | Canon PowerShot SD1200 IS / Digital IXUS...
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 | Cameras
Fuji S5200 view finder reads Frame No. Full
Go into setup menu by pressing menu, scroll to >set< then scroll to >frame number< and change the default 'cont' to 'renew' Save the new setting and leave the set-up menu. That should solve your problem.
Jul 25, 2010 | Fuji Cameras
!FRAME NO. FULL
Save all pictures to your computer.
Turn camera on, press the menu/ok button, select Setup, press ok.
select Frame No., change Frame No. to Renew, press ok.
Leave Setup.
Press the menu/ok button, select Setup, press ok again.
Select Format, press ok / ok until the card is formatted.
Now the counter should start over with 100.0001 again.
Set Frame No. back to Cont. to avoid to many images with the same filename.
Feb 22, 2010 | Fuji FinePix S5700 Digital Camera
'frame no. full'
You need to reset the frame count. Have a look at my post for this on my profile
Dec 18, 2009 | Fuji Finepix Z20fd Digital Camera
Come up with frame number full
The problem is ther internal memory is full or your external card is full and you have to reformat the card. Then you should be able to use the camera .
Apr 10, 2009 | Cameras
Frame full
I had the same problem with a fujifilm camera, the good news is that it's easy to fix. On the shooting menu (press menu when the camera is in shooting mode) there will usually be a set-up option, within that you should see "Frame No." or something similar- the two options for this are either "continuous" or "renew". If you are experiencing the Frame no. full error it means that you are currently set to continuous; TO SOLVE THIS PROBLEM SWITCH THIS SETTING TO RENEW.
Hope this helps!
Apr 05, 2009 | Fuji FinePix Z5fd Digital Camera
Built in memory full...?
I have new camera ,After shooting 12 photos it's show Built in memoru full and cannot shoot anymore
Jan 23, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Full frame??
Hello to all. Well after a few tries I figuered it out, all you do is hold down the arrow pointing > to the right at the back and thats it full screen, I guess pressing the arrow < pointing to the left reduces the size again. Just remember to hold it down for a few seconds.Hope I was helpful, take care all.. Happy Holidays
Dec 14, 2008 | Coby DP-768 7-Inch Widescreen Digital...
Fuji FinePix F45FD Digital Camera Logo
67 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
