Question about GE WBSR3140DW Top Load Washer
GE Washing Machine
Machine hums, water fails to drain even aftergoing through full wsh cycle
  • Spencer Dec 24, 2007
    I have taken the front off of my washer and when it gets to spin cycle, the little fan/wheel at the bottom/front/right of the washer will spin a bit and try to get started. I have to help it get started if I want the water to drain properly. I also have to empty the water manually, dumping buckets out, otherwise the laundry will still be soaked when the timer finishes. Is the motor stuck or is there something stuck in it. Any help would be great.
  • Logan727 Jan 04, 2008
    My water is not draining at all What should i do? I am totally clueless
  • 32 Answers
It sounds like the pump may have something stuck in it take the front off and removed the hose's from the pump and check inside the pump for coins etc.. if not you may have to replace the pump I hope this helps.
Posted on Dec 21, 2007
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Oct 02, 2012 | Whirlpool Washing Machines
My GE washer doesn't drain water.Even after the spin cycle is over, the washer is full of water. Please help.
Either the drain is blocked or your filter is full. Find out where the filter is, usually in front below door or behind panel in front. Clean this out & refit. Plug off the mains first. Check machine filter first & then snake out your drain.
Feb 10, 2010 | GE WSXH208A Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
My GE washing machine is stuck on agiation mode.
Jul 15, 2009 | Washing Machines
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Washer machine not draining water
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Nov 21, 2008 | GE WBSR3140DW Top Load Washer
GE Top load washer.
Hello rschneeweis
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
