Question about InFocus DEMO X3 1600LUMEN XGA DLP MMPROJ 6.8LBS Multimedia Projector
We have an Infocus X3 unit that is getting a yellowed image
The unit is showing a yellowed image down the left hand side of the projection....you can still see the image but it has yellowing only on
about the first 1/20 th of the projected image.
  • 2,237 Answers
The colorwheel is collapsing and needs replacing. you can get one from any infocus authorized service centers and do it yourself or have them do it. if you are in ny, try av solutions. they've always done good work for me.
Posted on Oct 16, 2009
I left my infocus x3 on ovrnight wnet down this morning it was shut down when i start it up fans and everything work normal but the bulb doesn't on and it is a fairly new bulb it have had the x3 for about...
it's not recomended to run constant for a day or longer. it may have overheated the lamp. especially if you've never cleaned it out before. take canned air and blow out any dust. but first remove the lamp and see if there is dust blocking the side vent. if there is a lot, the lamp overheated and prematurely blew.
Oct 30, 2009 | InFocus X1 Multimedia Projector
We have an Infocus X3 projector. It has been
the light tunnel is collapsing and needs to be replaced. contact an infocus authorized service center to either send it in for repair or purchase the part and do it yourself. try av solutions in ny. they're pretty good.
Oct 26, 2009 | InFocus X3 Multimedia Projector
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Black and white image on infocus x3
first reset the settings to factory default (menu, settings). if that changes nothing and the colorwheel is still in tact, the main board is bad.
May 07, 2008 | InFocus X3 DLP Projector1600 ANSI Lumens,...
Faded Black Strip on Side of Projection
I had a similar problem with my InFocus LP600 although my black stripe was straight up and down. I am guessing this is caused when the unit is bumped or dropped. This is not an easy fix unless you have a lot of experience with small tools and parts and you may need an extra set of hands. I found some tiny alignment screws under the lamp cover and hidden beneath a peel-off 0.5" x 2" black plastic strip. The screws are located between the bulb assembly and the main projection lens and are oriented 90 degrees apart around the light projection path. The trick is in getting the projector to temporarily function with the lamp cover off -- it has an interlock tab on one edge that pushes on a microswitch when closed. We turned the projector upside down but raised on some slats for heat dissipation, gently held the interlock switch in with a small screw driver, and plugged in the power cord. After pushing the power switch to get the image, I adjusted the tiny screw that is angled towards the front of the projector and the stripe dissapeared! Since your stripe is angled, you may need to adjust both alignment screws. The screw heads are very tiny torx bit types but I was able to use a 3/64" (.05") allen (hex) wrench that came in a set of cheap jewelers type tools that are widely available. Be very careful while operating the unit with the lamp cover off as there are very hot surfaces and exposed wiring.
Nov 08, 2007 | InFocus LP 600 Multimedia Projector
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
299 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
