Question about Whirlpool GEW9250 Electric Dryer
Whirlpool dryer, model# gew9250pw1, approximately 2 years old with no previous problems. Power goes on control panel but will not start drying cycle. A sensor light comes on. Have tried manual cycle. Have also had power off for 2 30 minute periods. Is there any other way to try reset before calling repair service?
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
  • 172 Answers
SOURCE: whirlpool duet dryer will not
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Posted on Dec 02, 2008
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
canbruce75
  • 1776 Answers
SOURCE: Whirlpool Electric dryer LE5800XSW3 won't dry
This repair will most likely be much cheaper than buying a replacement, unless you just want to make a jump to gas. First, check the venting for the dryer. Clogged venting can cause prolonged drying times. It could also be caused by a blown thermal fuse, bad heating element or high limit thermostat. If the venting is clear all the way to where it exhausts to the outside, then I would suspect bad thermal fuse or high limit thermostat. They can be tested using a multimeter or ohmmeter. It is best to replace both the thermal fuse and the high limit thermostat at the same time and they often come from the parts supplier as a set. I'll attach a photo of a fuse/thermostat for reference. Really sorry for your trouble and I hope this helped some. Best wishes.
Posted on Sep 23, 2009
Testimonial: "Thank you for your detailed response . . . "
Timer skips time have changed sensor bars and wire harness on gew9250pw1
It is normal for an electronic timer to skip time if the dry sensor senses the clothes are nearly dry.
Aug 05, 2014 | Whirlpool 8546219 Compatible Control Board...
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
I have a Whirlpool Duet front loader Washer approximately 6 years old. The control lock is on and I can't start the washer. How do I resolve this problem.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
Unresponsive control panel- Whirlpool duet dryer 4 years old
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Dryer
I have a whirlpool duet dryer GEW9250PW1 and the control panel wont come on, I have took out the circuit boards cleaned them with contact cleaner blew out the top and took off the bottom panel and blew it out, after all that it still wont come on unless you unplug it for at least 20 minutes.
Oct 07, 2009 | Dryers
The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Aug 27, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer ran fine, then when tried to dry another load, would not st
Mar 21, 2009 | Whirlpool Dryers
Whirlpool GEW9250 Electric Dryer Logo
411 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
