Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
No picture or sound
It will power on but no picture or sound change the lamp and ballest
nothing any Ideals
  • Rich B Dec 21, 2007
    Order a new wheel let you know the out come
  • Rich B Jan 14, 2008
    Bad color wheel works fine now
    Problem Solver:
  • 8 Answers
Ether the color will is bad or the DMD bord is having Problems try to clean it I tell how in my ether post.
Posted on Jan 02, 2008
Bad fan
di you replace the ballest that power up the lamp
Nov 18, 2013 | Akai PT50DL24 Television
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Picture went out had sound..replaced shuts off and after a few minutes..that stopped now back to no picture but sound.. I suspect the Ballist..want to replace it ourselves but need to know where...
This unit has cooling fans and it sounds like they are either plugged or not working. When a ballest usually goes out it does not come on and then go out. It is the coming on part that is hard for the ballest to do when going out. Sounds like over heating problems and if it is the ballest it could be any were on a tv and in many different locations. I would type your model number in and replacement ballest for this model number and go from their. Thanks
Oct 05, 2010 | JVC HD-52Z575 52" Rear Projection...
No Picture
Usually sound with no picture may mean one of two things.
1) Either issues in the power supply feeding the panel it'self - not the audio portion or -
2) The lamp ballest 'back lighting' supply has failed.
If you call a trusted local service center they should be able to give you an estimate of repair over the phone. You may try a couple of shops for estimates. Can be repaired.
A/V Media Guy
Feb 03, 2010 | Polaroid FLM-323B Television
We get sound on our sanyo, but no picture. When
Probably out of warranty?
this is an issue with either one of two things,
1) Power supply
2) Lamp 'Florecent back lighting tubes' ballest.
Depending on the service shop rates, the labor is more than the part. Call around and get some price quotes. Worth your time. These set's are still expensive?
Now if it's a 15" . Buy a new one. They are just a throw away item these days.
A/V Guy
Nov 19, 2009 | Sanyo Vizon LCD-15A2 Television
WD 52525
Aug 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
