Question about LG 42LC2D 42 in. LCD HDTV
LG 42LC2DR hard drive intermittently will not initialize unless HDD FORMAT is performed . ultimately deleting hard drive contents. it happens on start up sometimes, or during operation as u select the menu options screen. sometimes weeks apart ,months apart. is covered under ample warranty but fearful technicians find nothing wrong when they are called out . is this common?
  • 36 Answers
SOURCE: LG 42PC1RR No picture -- only sound !!
yes i have had many problems with my lg plasma. i had to replace three boards in the back of the tv. it is most probably the y sus board which has failed.
Posted on Jun 19, 2009
  • 188 Answers
SOURCE: LG 42LC2DR takes ages to start
Check for bad caps in the power supply.
Posted on Jul 24, 2009
tvservice306
  • 458 Answers
SOURCE: LG 42LC2DR - tv channel picture & freezes Intermittently
replaced main board
Posted on Aug 13, 2009
  • 10 Answers
SOURCE: LCD DVD HDD problem
Sounds like you may need to replace the hdd in this unit
Posted on Mar 19, 2010
  • 3 Answers
SOURCE: LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
Posted on Nov 14, 2010
Do i need to initialize my j book for it to be recognized. my j book is not recognized on my computer?
If you have already put files on it, initializing will most likely delete everything!
I assume "initialize" refers to Windows asking if it should format the hard drive.
If your drive is suddenly not recognized, the filesystem has probably gone bad. This can happen if you disconnect the drive while data is still being written to it. For this reason you should always "safely remove" USB drives.
If the filesystem is corrupted and cannot be accessed, you might be able to save your data by using special recovery software. One tool of the trade is the commandline-based "testdisk" utility for Linux, which I have succesfully used to restore entire filesystems without any data loss.
If you want to rescue your data, the worst thing you can do now is to initialize the drive or use it in any way that changes the content.
If you don't care whether the content is deleted, just initialize it or do whatever it takes for it to be recognized.
Please state if you want help on restoring your data.
Jul 03, 2014 | Western Digital 320GB MyBook External USB...
Unable to detect my hard disk HM320HJ, after i m doing low level formatting using hdd low level format tool....
I believe low level formatting will leave the drive as raw. meaning there is no partition. You need to do an unconditional of quick format such as before installing windows. or install the drive in another working computer and access it through drive management witch will allow you to initialize and format the drive to an NTFS partition.
Oct 23, 2013 | Samsung Spinpoint MP4 HM320HJ 320GB 7200...
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Format problem with Lacie portable HDD
Format the drive using another utility then delete the partitions on the drive and try again
Aug 17, 2012 | LaCie Rugged All-Terrain (301017) Hard...
How can I delete the contents from my Toshiba external hard drive so I can use it for a new Toshiba laptop? Thank you in advance!
Hello jeannietx, to "Delete the {Data / Files} go to the "Disk Management."
  • Next, {Right} click on the Computer 'shortcut,' select "Manage."
  • In the next 'window that opens, 'open the "Disk Management" in the [Left area] of the 'window.' paul7of9_98.jpg
  • Now, look 'under' the "Volume" tab, paul7of9_99.jpg and find the 'External' [HDD] 'letter' ie: (F:).
  • Next, you can "choose to Format the Hard Drive.
  • This will "Erase 'all' Data on the HDD.
  • "You can select to "Delete the HDD, instructions [below]!
  • Click on the "Volume" to open, and select to "Delete Volume..."
!Attention: "Another 'way' to "Delete the 'contents of the HDD {Data) is to do a Disk Clean-up."
  • All {areas} are accessible, by "right clicking on "Volumes."
  • Restart the Computer when finished!
"Please let me know if you 'need' further assistance, or the 'solution' helped?
"By posting a 'Comment" or 'Rating' the solution.
Thank you; your 'response' is important to me!" paul7of9
Feb 28, 2011 | Toshiba 120GB USB 2.0 Portable External...
Xbox 360 Hard Drive Device (HDD) deleting content
Reformat the hard drive using the Xbox 360 system. If this does not work, then it is time to get a new hard drive for your system. We sell 20GB hard drives for the Xbox 360 so you can contact us and we'll be glad in helping you.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Console
LCD DVD HDD problem
Mar 19, 2010 | LG 42LC2D 42 in. LCD HDTV
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
Western Digital Passport 320gb esternal usb The
Hi ,
If the volume hdd 320 gb is new may be you will need to format it
Try to format it and see if the same error happens:
follow these steps below
To format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system or the file system you are used to.
hope this help you
Regards
uttam
Jan 19, 2010 | Western Digital Passport 320GB External...
Hard Drive recovery
Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
LG 42LC2D 42 in. LCD HDTV Logo
167 people viewed this question
Computer Repairing
Computer Repairing
