Question about Kodak EASYSHARE 5100 All-In-One Printer
New ink cartridges not registering - Kodak EASYSHARE 5100 All-In-One Printer
    Sergeant:
  • 151 Answers
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* Try cleaning the printhead then print a demo page
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Posted on Oct 02, 2009
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
I've gotten three new black ink cartridges from different sources and none of them are registering in the printer which is making me wonder if this is a problem with the printer. I've cleaned the ink...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | Canon PIXMA MX310 All-In-One Printer
My new lexmark 33 color ink cartridge will not register in my printer, nor will a replacement one. The old one does register when put back in.
Sorry but I need to ask this.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
After replacing my ink cartridge ,now it register
If the cartridge tape covering the ink dispenser and the cartridge is properly seated in the transport, the chances are that the cartridge is defective. If you are using aftermarket or refilled cartridge, replace it with a new OEM cartridge should clear the problem. I would try the OEM method first to make sure that something else is not wrong. If the OEM cartridge works, return the faulty cartridge for a replacement or refund.
Let me know if this works. Thanks.
Nov 10, 2009 | Generic Memory Compatible Epson T027201...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
how old is this one? And sometimes, those 'replacement' cartridges are anything but standard.
recycle your printer responsibly
Mar 16, 2008 | HP Photosmart C4180 All-In-One InkJet...
Ink low error
Hi there the ink cartridges are designed to be used once. Most of these new ink cartridges have a set chip on it once you have installed a new cartridge it registers that a new one has been installed and resets the ink counter for that cartridge. When you refill the cartridge it doesn't reset the chip.
I don't know how to reset the chip but the best suggestion I can offer is to purchase a compatible cartridge that has been reset.
Thanks J
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
