THIS IS A REVISED POST from my previous one. So lets start over.
I have 2 Motorola P110 2 Ch Radios. One powers up and when I press the PTT button the red light comes on, so I think it works. The 2nd one when I press the PTT button the light does not come on and it has a tone that turns off after I release the button. Switching batteries did'nt change. I want this unit to talk to the other unit. Is there a way to re-program them?
Is it possible that the unit in suspect has gotten locked into receive only mode?there are units set up this way, can you go into the system on this radio and re-set to the default operating mode?
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Did the radios previously work together? If so, you have one radio in need of repair.
If the radios are new to you, and you do not know if they previously worked together, it could be a simple programming problem. Take it to your local Motorola dealer to check the programming.
One simple test to see if you have one with PL and one CSQ, is to press the monitor button and see if the two radios can communicate when they are in open squelch mode. (The monitor button will be one of the side buttons near the PTT.)
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
MOTOROLA GP-2000 Programming Instructions Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If
the radio is turned on, turn it off. Press and hold the MON button and
turn the radio on. A ringing tone will be heard,which indicates that
the radio is in Programming mode. The PW and [] indicators are
displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
On most Motorola radios, to remove the roger beep, while powered on, you need to press the menu button until the Roger Beep indicator in the display starts to flash. Press on the + or - to change status. Press on the PTT to save and exit.
Hope this be of some help. Pls post back if it worked or should you need additional information.
