Question about Miele Novotronic Premier 500 Front Load Washer
We are getting a f50 fault can you advise what this is
  • 10,515 Answers
F50 = Motor Stalled
The motor is stalled first thing to check is that there is nothing stopping the motor in between the tubs under the unit at the stater motor. If every thing check OK the rps sensor will most likely be at fault. This is located under the unit to the right of the stator motor. I am sure you have researched this and have found this to be a common issue! The manufacture has come out with a kit for the f-50 f-51 error code. The kit is a new control board,wire harness,and sensor.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 02, 2009
  • 10,865 Answers
This is a common problem with your machine. the F50 means the motor rotor position sensor (RPS) senses no rotation. Definitely call the store and or the manufacturer and put them on notice that you have learned that this is a common problem and you want satisfaction otherwise you will go to the better business bureau and the state attorney general. Don't back down as you are one of numerous Miele customers dealing with this issue
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
MACHINE STUCK ON F50
Fault code f50 is a stalled drum drive motor fault. Move the wash drum does it move freely? If it is stuck look and see for anything obvious that might be jamming it. Another problem could be the motor rps sensor not sensing the motor turning. check sensor for anything in its way
Jun 05, 2012 | Zanussi ZWF1430W Front Load Washer
Keep getting F50 code cannot reset washer
There have been a lot of reports where technicians have been ordering RPS's prior to the common fix for the problem which is the control board. This is a common problem and the control board fixes F50 faults in most cases.
Nov 07, 2011 | Whirlpool WTW6400SW Cabrio Washer
I get a f50 fault code on a model 110.2704. kenmore. I checked the basket and it moves freely. I unplugged the motor lead and got a f51 code that was expected. What next?
F50 = Motor Stalled
The motor is stalled first thing to check is that there is nothing stopping the motor in between the tubs under the unit at the stater motor. If every thing check ok the rps sensor will most likely be at fault. This is located under the unit to the right of the stator motor. Im sure you have researched this and have found this to be a common issue! The manufacture has come out with a kit for the f-50 f-51 error code. The kit is a new control board,wire harness,and sensor.
Thanks and have a nice day.
Jun 23, 2011 | Cameras
Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Washer gives F50 error. I've taken top off and
Press pause cancel once and that should do it. If not the repair manual advises calling for service. Lets see what the F50 is...hold on...Motor stalled, rotor position sensor detects no motion from the tub, does basket move freely? If basket moves freely see test#3 in the repair manual HERE
The manual gives readings to verify and has a long detailed complicated set of IF's for this machine. Good luck
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 fault on maytag MTW6500TQ washer after apprximately 1 minute of startiong cycle
Two things cause the dreaded F50 code. (motor)
1. The machine control
Bravos MTW6600T
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MTW6600T+-%3d%3di1469076&PartID=1469076
2. The stator
Item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136402&diagram_id=1303991#d1303991
The upper cover of the stator comes in kit form and has been known to also cause the dreaded F50 code.
http://www.appliancepartspros.com/part_details.aspx?part_id=4327312&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5136402%26diagram_id%3d1303991
All of them are some what costly repair(s) in my book but cheaper than a new machine.
I have yet to change a Stator for an F50 Code.... but have changed a lot of machine controls (most often failure) and stator cover kits (occasional failure) that corrected the problem.
Just being honest. Thanks for using FixYa!
Kelly
Oct 13, 2009 | Maytag MTW6500TQ
Whirlpool cabrio model wtw6200swz, desplays fault code f50
make sure the basket is "free" floating. F50 is a stalled motor read. This really neds to be serviced by a technician.
Feb 23, 2009 | Washing Machines
Washer starts, then shows fault code
Bravos MTW6600T
2. The stator
Item 17 this link:
Feb 21, 2009 | Maytag MTW6500TQ
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Miele Novotronic Premier 500 Front Load Washer Logo
1,108 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
