Question about Fuji FinePix A850 Digital Camera
Doesn't power on but clicking sound
When power button is pressed and held pressing, it would continue making clicking sound..doesn't get powered on and nothing is on the display with no extension of lens.... bought new batteries but didn't work.. 1st i thought it would be a common lens stuck problem but after opening the cover and externally powering the lens extending motor i found the lens is not stuck. ( i am sure i didn't damage any component or circuit during this process) it still making this sound... why? i used it only for a day... and after 15 days keeping unused with batteries inserted when i tend to power it on it start making that sound... its a new one but i do not have any warranty as it was sent to me as a gift from other country....please help me..
Bluebeard
  • 6 Answers
SOURCE: lens cover stuck open, power wont come on
I have been told by a camera mechanic i contacted on line (in America) that there is a fuse within the camera which is very small and soldered onto one of the boards. I was unable to get a precise location and the only details were that this component was either white with black writing or black with white writing.This may have a bearing on your problem.
Dennis
Posted on Nov 26, 2007
  • 29 Answers
SOURCE: Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Posted on Jan 05, 2009
  • 244 Answers
SOURCE: My shutter will not open. The power button presses
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Posted on Jun 20, 2009
dlundmark
  • 797 Answers
SOURCE: when we press the on/off button, the camera make a
Make sure the battery or batteries are either fully charged or are new. If it still will not work, then the camera needs repair, and it may be better to sell it then for parts or repair, as is on a site such as Ebay.
Posted on Mar 03, 2010
lock123
  • 6831 Answers
SOURCE: About seven days ago bought
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
How do I fix Canon error message 2700?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Thanks.
Feb 15, 2015 | Canon PIXMA Office Equipment & Supplies
How to reset canon pixma ip2800 series
dear
  8. Thanks.
Feb 02, 2015 | Canon Office Equipment & Supplies
Mg 5350 6502
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Nov 21, 2013 | Canon Office Equipment & Supplies
When i press the power button on the remote to turn my 52inch tv on it doesn't start and makes a clicking sound as if its trying to come on
What is the brand name to your TV? Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Televison & Video
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
Dec 29, 2009 | Kenmore HE2 Plus Front Load Washer
When using palmtungsten e2 message appears "Reset memory Mgr.c line 3751 free handle"one of my program i cannot use. thanks help who do i contact
The first thing to do is to make sure you have everything backed up on your PC. Then do a hard reset. Here are the directions for that:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. Best wishes....Hope this helps.
Sep 18, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I have the same problem! I use to get on just fine.
Try doing a hard reset. Make sure you have everything backed up on your pc since you will have to do a hotsync once you do the hard reset. OK to do a hard reset do this:
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Sep 18, 2009 | Palm TX Handheld
Can't use touchscrren - i've don't soft resets - no luck cleaned the screen won't calibrate
Try doing a hard reset. To do this you can follow these steps:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
Sep 16, 2009 | Palm Z22 Handheld
I forgot the password for mine, how can i get around this to cancel or even change the passwprd?
If you have forgotten your password you should be able to use the password hint to figure out what it is. You can try a soft reset to see if that will clear the password but I am pretty sure this won't help. To do a soft reset use the tip of the stylus or something pointed like a paper clip and inset it in the hole on the back of your palm pilot. This will make the unit reset it's self. If this doesn't help then you must preform a Hard rest to continuing using your hand held. You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
3. Wait for the Palm Powered logo to appear, and then release the power button.
Aug 05, 2009 | Palm TX Handheld
Fuji FinePix A850 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
