Question about Epson Stylus C64 InkJet Printer
Red lights i just put a new cartridge in my c64 (generic) both the red lights came on flashing and the carriage went to the right and stayed there. Any ideas how to fix?
  • Anonymous Jun 21, 2008
    i have both red lihts on and all my ink cartridges full
  • Epson Master
  • 1,879 Answers
Generic as in 3rd party ?
printer is not recognizing them, try changing a cartridge
Posted on Jan 04, 2008
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Both red lights flashing
If the lights are flashing together then this will be a carriage error, if alternately then this will be the Service Maintenance request which will require reset software such as the SSC Utility. http://www.ssclg.com/epsone.shtml
Feb 08, 2010 | Epson C64 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
I put a new black ink into my printer it seemed alright, then when I went to print a document it made a strange noise and the green light went out and the red light went back on. I have tried pressing the...
the cover over the cartridge was not closed properly is my guess - was the noise like a grinding sound? - if so, it was the toothed drive belt jumping teeth on the drive roller.
Turn off power to the printer and GENTLY pull the cartridge carriage back t the center using the drive belt. Next remove and re-insert the cartridges and make sure the cartridge cover is down and locked.
Nov 18, 2008 | Epson Stylus C46 InkJet Printer
Strange noise
dear cindy726
your printer is having a hardware failure.please sent it for serviced
Apr 07, 2008 | Epson C64 InkJet Printer
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
Epson Stylus C64 InkJet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
