Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washing machine stops in mid cycle
My whirlpool duet front load washing machine stops in the middle of its cycle (usually drain cycle). It flashes an F 21 on the display. What the heck is wrong
    President:
  • 1,653 Answers
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My whirlpool duet sport washer just stops completely mid cycle and shuts down
If it has a safety switch that shuts the washer down when the lid is open, it could be going bad. It's a simple repair.
Jun 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Stops in middle of cycle and won't drain or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 02 F
pump is obstructed and needs to be cleaned. Look in this thread for how to clear a duet sport pump trap.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire stackable front load washing machine
ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
653 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
