Remote wont work , child lock on - Televison & Video
    President:
  • 1,653 Answers
Most child locks require you to hold down a buttongn for a period of up to 10 seconds and the lock is released. Try holding down the Enter button for up to 10 seconds. Also if the remote does not work then try replacingthe batteries - this often helps.
Posted on Oct 02, 2009
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
Oct 07, 2016 | Cars & Trucks
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
Removing the Child lock when remote doesn't work
CHILD LOCK CAN ONLY BE REMOVED IF REMOTE IS NOT WORKING, OPEN YOUR TV AND CHECK FOR 8 PIN INTERGRATED IC..24C04..ANY NUMBERS LIKLY TO BE FOUND AND REPALCE WITH THE SAME NUMBER, IT WILL WORK
Oct 14, 2009 | Hitachi C21-FL21F 21" TV
Child lock on and tv wont turn on no remote
OMG it worked my tv was locked on child safety for 1 month you have to get any universal remote and try all the codes mine was 0224
Jul 24, 2009 | Philips Magnavox 27MS343S 27" TV
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Apr 10, 2009 | Televison & Video
I cant turn off my child lock
Press STOP button for more then 5 seconds to cancel child-lock function.
Jan 13, 2009 | Sony DAV-DX255 System
TV WONT TURN ON
Well the universal remote will need to have the ability to gain access to the menu so you can go and change the settings for the "v-chip" or what ever the child lock is that you speak of. I hope you know what the password is or it may be "locked" for a very very long time. I say this about the password because usually this control is password protected. Yours may not be but,.... Good luck. What you seek is in the menu sequences somewhere. Start pushin buttons!
Apr 09, 2008 | Televison & Video
Magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Jan 20, 2008 | Philips Magnavox 27MS343S 27" TV
Child lock
my daugter lock my sharp aquos with the child lock and i don,t know the pin
Nov 25, 2007 | Televison & Video
Televison & Video Logo
576 people viewed this question
Top Televison & Video Experts
Electro Med Services...
