My laptop has Acer Arcade Deluxe & appears not to work correctly
My laptop has Acer Arcade Deluxe & when track 1 has played the programme goes to track 8 then track 9 & then to track 14.Something is not working correctly. Track 2 should follow Track 1 & Track 3 should follow Track 2 etc.
  • 378 Answers
You must have selected random play. Just uncheck it and it shall be done.
Posted on Oct 02, 2009
I have an Acer Aspire5735 I ignored an update for the Acer Arcade Deluxe this month, now the arcade does not play dvds nor can I locate any info on the update
If there is not an automatic update function I would recommend removing the Acer Arcade Deluxe, if it's only used for DvD's and download a much better free programme VLC media Player, which will work much better available here http://www.videolan.org/vlc/
Feb 28, 2011 | Computers & Internet
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
Play dvd, and it freezes!
go to the acer website and see if there is a new update for the bluray player.
Aug 12, 2009 | Computers & Internet
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
When I try to launch a Blu-Ray movie Acer Arcade Deluxe attempts to connect to what I guess is a non-existant web site which it fails to do. This is the end of your movie playing experience. There is no...
Ok I,m not sure i can solve the problem for you, but have had problems with my acer 6920 G. Hopefully this will help. I was playing blu ray discs on my acer 6920 G wich i believe has the same sony/nec Optiarc blu-ray player. It was playing blu rays fine for a while. then as newer and newer releases were coming out it would not play some blue rays from certain manufacturers (Fox). Then newer releases from other manufacturers would not play. I was getting updates from acer arcade deluxe that would allow me to play some of the newer releases. The only problem i was having was that the updates (patches?) were not keeping up to the newer releases. The last update from acer was corrupted or somthing was wrong with it and then my blu-ray player wouldn't play anything at all. To solve the problem I reinstalled acer arcade deluxe using the acer e recovery management. This fixed the problem. But now back to square 1. My older blue rays will play but not the newer ones. I've been going over this problem for a while now. The Acer site was no help at all. The e-mailed me some solutions both hardware and software but weren't even close to what the problem is. You can try Cyberlink Power DVD 8 and it runs better than the Acer Arcade Deluxe. (They write the updates for the acer arcade deluxe) It is expensive the last time i checked. Hope this helps a little.
May 01, 2009 | Computers & Internet
Acer Aspire 6930 won't play Blu Rays
Your DVD is not Blue Ray capable. You would need to purchase a Blue Ray DVD player for your laptop, just having the software does not allow you to read them.
Apr 11, 2009 | Acer Aspire 6930-6455 Notebook PC
Acer 6920g has gone onto acer arcade deluxe cinema .
I have had the same problem ... that happend to me when I press the arcade deluxe button on the blue gem controler on the left. when I tryed to run vista again it keeps going to the arcade deluxe system ...
the only solution for that case that works with me when I run the system recovery and installed fresh copy from the windows vista that came with my laptop ...
I hope that helps you in your case.
Feb 10, 2009 | Acer Aspire 5100 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
May 19, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
