Question about IBM ThinkPad T40 Notebook
Freezing I have had two of these machines which have both developed the same problem.  After a while of using it, it completely freezes, won't move, turn off or nothing.  I have since tracked to it when ever the machine is moved, no matter how slightly. Is there a quick-fix or a fix at all or should I be looking at a new machine. I have been previously advised that it is something to do with the power supply but a second opinion and advice on how to repair it wouldn't go a miss. Many thanks. Jonny
    Novelist:
  • 188 Answers
I have seen this on the T40 series when the video chip on the motherboards fail. the only fix is a new motherboard (usually about $150-$200 plus labor.
You may want to check if they are under warranty - a lot of these had 3 years on them and may still be covered. just google "ibm warranty lookup" and there should be a link to IBMs site for warranty info. They will honor warranty even if you are not the original owner.
Posted on Dec 21, 2007
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
Ps3 60gb freezing
Try this use your vacuum to suck out any dust that is in machine from front and back. Use compressed air (duster used on electronics) and spray the cd area and back area again, vacuum out. If this doesn\'t help then Call Sony PlayStation for replacement of machine.
Jun 25, 2013 | Atari Tales of Graces f - PlayStation 3
Soft serve machine freezing solid
POSSIBLE CAUSES• Mix hopper is empty, freezing cylinder starved for mix.• Mix in hopper contains ice particles, mix feed tube clogged.• Machine turned too cold
ACTION REQUIRED• Add mix to hopper. Put machine in wash mode to help thaw freezing cylinder.• Pull mix feed tube to fill freezing cylinder. Replace mix feed tube and put machine in wash mode to help thaw mix in freezing cylinder.• Follow manufacturer's recommendation for the proper temperature for the mix being used.
Apr 12, 2013 | Ice Cream Makers
Frost developing inside the refrigerator on the bottom two shelves
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Sub-Zero Refrigerators
Freezing
I took back 3 units playing such games. If this is a settop box I have found them to be very flakey items. **** Smith has replaced them and I have upgraded twice now. The best so far is a Topfield TRF7160.
Dec 14, 2011 | Televison & Video
XT5000T freezing up and becoming unresponsive
If you're sure its not a virus then it probably is your hdd giving up the ghost. How old is it?
Apr 23, 2009 | Everex StepNote XT5000T Notebook
Replace parking brake cable
if your not experience with brakes i won,t attempt replacing the cable. if you always have a freezing problem use a wheel chuck.
it,s a wedge u put against the tire so a car won,t roll
Dec 15, 2008 | 1996 Honda Accord
Phone freezing
hi all viewers `this is a good tip for your nokia 5310. well your phone is freezing cus you have to much memory on the phone the phone has a memory on its self witch is 20 mb. if you fill up like 15-20 mb it will slow your phone down or freezing completely. you can fix this by moving files to a memory card on the phone freeing up space i recommend you store 5-7 mb on phone memory. 100% success if not you have a problem
Jun 27, 2008 | Cell Phones
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
IBM ThinkPad T40 Notebook Logo
73 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
