Question about Electric Electrical Supplies
Flickering I have six low wattage (15 W dimmable flourescent) lights on dimmer in my kitchen, I think they are well below the amperage for the circuit, but the light flicker, go out and come back on. Should I replace the dimmer ?
  • 87 Answers
#1 cause is a bad lamp,try changing that 1st, 2nd if they are two lamp fixtues you ballast could be going bad/or is. Another solution could be you have a loose common/neutral which is normally the white wire @ the light itself of if it is junctioned @ your switch. I would check those items befor spending the money for a new switch. hope this helps.
Posted on Oct 03, 2009
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
Jun 26, 2013 | Electrical Supplies
Light kit does not work... It keeps burning out the lights .Do not know where to get it fixed or replaced.
get a meter and see what type of volts you are running through your fan,sounds like to many volts or bad wire keep triping the system,good luck
Aug 11, 2011 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Electrical Supplies Logo
117 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
