Question about Sony VAIO VGN-NR120E/S Notebook
Vaio screen flickering
My vaio vgn-cs215j got 4m us 6 months ago got a prob..its screen started flickering nd after sometime it stops...i want to know what may b d reason and hw d prob cud b solved...hw much it wud cost if i giv 4 service...aprrox
leecom72
  • 4806 Answers
SOURCE: Sony VAIO VGN-CS215J need vista 32bit drivers
Hi there.
The audio device should be Realtek.
You can download the driver from here >>>>>>
http://support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/Audio_Driver_Realtek_6.0AM_Q_32_6.0.1.5657.zip&ip=Preinstalled_Drivers.htm
Good luck
Posted on Jun 12, 2009
SOURCE: My capture and av mode button do not work on my
i have a sony viao vgn css220j laptop which key using keboard for booting
Posted on Jul 15, 2009
  • 476 Answers
SOURCE: Sony Vaio Laptop VGN-CR240E LCD screen flickering
Hi - I have replaced lots of LCD screens,it can be done
HOW TO REMOVE LCD PANEL OF MY ACER LAPTOP.
First ===>>> Remove all power and battery
Each machine is different in construction and size,
but they operate in the same fashion,motherboard,power inverter,lcd panel and cable connecting them together,also there may be a wireless aerial and or camera as well inside the lids frame housing the lcd screen so be careful while dismantling the front frame,it should be a good tight fit,
the lid has a base and a front panel covering the workings of the screen and wiring in a compact frame,remove the screws from the front panel and lift the front frame free from the base,remove the power panel by the screen next to the keyboard this should expose the motherboard insides,then unplug the inverter from the screen,unscrew the screws holding the the frame and carefully lie the screen on a flat surface to unplug the data cable from the rear of the screen, top of the screen rear contains IC chips required to make the pictures,
DO NOT TOUCH THESE >>> STATIC KILLS
It dosent mater if the screen is already dead just remember this when you fit the new screen
Hope this helps,Misterdj
Posted on Aug 10, 2009
MUKHTAR
  • 2017 Answers
SOURCE: SONY VGN CS215J Shut down by itself
just start the laptop in safe mode with command prompt and run chkdsk /r/f command
how to go to safe mode with command propmt just press F8 KEY when you switch it on.
Posted on Sep 10, 2009
  • 1146 Answers
SOURCE: Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Posted on Nov 10, 2009
Sony vaio laptop has lines at the bottom of the screen
The screen is going bad and needs replaced. Can get one on e-bay and do the work yourself or get a technically minded friend to help.
Jan 23, 2014 | Sony Original Vaio Vgn-cs215j Webcamcable...
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Please take time to rate me
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
My sony vaio vgn cs215j sometimes just shut off
The CS series are known to have a Fan issue. If you call phone support you can get a fan replacement for up to two years after purchase.
Sony agent.
Feb 17, 2011 | Sony VAIO VGN-CS215J/W Notebook
Flickering below the task bar and now flickering on entire screen
If it is in warranty take to service center Or else, try to press & hold the bottom of the display screen. Becuase it may be problem in the display or in the cable or in the conncetion.
Jan 13, 2011 | Sony VAIO VGN-CS215J/W Notebook
Sony Vaio VGN-CS215J has a line across the display in the bottom of the screen...What do I do to fix this? I don't have warranty on it.
it is a known issue with the VGNCS100, 200 and 300 series Computer. You will get the Service for free.
http://esupport.sony.com/US/perl/news-item.pl?mdl=VGNCS215J&news_id=377
Apr 08, 2010 | Sony VAIO VGN-CS215J/W Notebook
Driver av mode sony vaio VGN-CS215J
im from malaysia and bought it from malaysia, my laptop is vaio VGN CS36GJ.. im having the same problem as stated up there.. my touch pad of sound, av and capture button is not function.. can u please tell me where should i go or what should i do?
Dec 13, 2009 | Sony VAIO VGN-CS215J/W Notebook
Sony Vaio Model: VGN-cs215j
Try looking on this Sony page, it might helpyou.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB
If this has helped you then please rate me!
Aug 23, 2009 | Computers & Internet
Sony VAIO VGN-NR120E/S Notebook Logo
454 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
