Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN 5065w
No picture or sound replaced Lamp and ballast still will no come on
it power up and shut downs and try to restart again all led flash
    Genius:
  • 1,153 Answers
You have a fuse or 2 open.
Posted on Dec 21, 2007
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
Apr 17, 2011 | Samsung HL-R6167W 61" HDTV
I have a Samsung DLP HLN-5065W that turns off after about a minute with 3 blinking lights. The picture is on and looks great. It's like something maybe over heats after a minute. Thanks, Rudy....
Lamp , if you have never replaced it!
Mats has them for $99.00 1-800-628-1118
Encompass Parts Distribution has Parts for this Model
and may the free service manual that you can print out online.
They will list PN # /Prices. 1-800-638-3328
I have the same TV as Yours .Had to replace Lamp and Color Wheel on mine.
Oct 14, 2010 | Samsung HLN5065W 50" Rear Projection...
We have a samsung HLN 5065 w projection tv.
Hi,if you hear clicking it could be the board that powers the lamp its called the ballast Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also pay attention to sounds off buzzing which could indicate a color wheel issue.
Dec 09, 2009 | Samsung HLN5065W 50" Rear Projection...
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
I have a Samsung HLR6168W DLP that intermittently shuts itself down,the sound stops, the picture disappears, the screen goes dark but not completely off. A few moments later the picture returns, but no...
its the problem of inner lamp that is near to end of its life and it needs replacement.and what the thing is happening is the indication of faulty lamp.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | Samsung HL-R6168W 61" HDTV
Samsung HLN 4365 wxixaa with Light engine failure????
When the tech said light engine what he ment was DMD board, the DMD board is the most important component on the light engine and most expensive, but still a lot cheaper then the entire light engine.
The DMD board can definetly, and often does cause intermitant errors. Your problem is absolutely not the Ballast, all the ballast is supply the power to turn on the lamp.
Your tech was right to go to the DMD board, the only other option that it could be is a digital board, you would have to see if it is doing this on all inputs.
Mar 03, 2009 | Samsung DLP HL-P5663W 56" TV
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
