Monitor comes on for 2-20 seconda then goes blank
    Problem Solver:
  • 12 Answers
First check your computer with the viruses if infected remove the same if still problme persists then You can check your ram, if still problems comes you can check bu putting the graphics card in pci slot , if still image is not coming then change your motherboard
Posted on Oct 02, 2009
    Guru:
  • 355 Answers
Check the any screen saver is running or not
When I turn on the computer, the monitor comes up
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Gateway FPD2275W LCD Monitor
When I turn on the computer, the monitor comes up normally and then goes blank. If I then recycle the power on my monitor, it comes on and works normally. If I plug a device into the USB ports on the...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 27, 2010 | Gateway FPD2275W LCD Monitor
The display come on the monitor the goes blank.
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 15, 2010 | ViewSonic VG181b 18.1" LCD Monitor
Monitor goes blank but is still connected
Do bios update on Computer.Select the product number and search on Website for bios and than try the monitor
Oct 13, 2009 | Computers & Internet
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
