Question about Dewalt DW983K - 2 heavy - duty XRP 1/2" 14.4v cordless drill/driver kit
Part # of the Voltage Regulator in Dewalt Drill
What is the Part # of the Voltage Regulator in a Dewalt DW983 Trigger Assembly. Its a 14.4 v cordless.... Thank You
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
The part number for the switch is 152274-19 . Dewalt doesn't sell the individual parts for the trigger assembly. It really depends on the manufacturer of the trigger at the time of production. You should be able to locate a company name on the side of the trigger switch assembly. It may be Marquardt. I am unaware of any way to order individual parts for these type switches. If you find a source please post.
Posted on Oct 02, 2009
Challenge xtreme
The power cord for the charger is not suppose to be "a servicable item". You're suppose to buy a new charger. But it could be replaced if you have the skills.
Aug 02, 2014 | Dewalt dw983 14.4v Dc 1/2" Cordless...
Dewalt dw983
It could be due to bad brushes or commutator. You would see lots of sparks coming from it.
Apr 26, 2013 | Dewalt DW983K-2 Battery 1500mAh, 14.4V,...
Good battery but drill won't run
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Jun 09, 2011 | Dewalt DC925KA Factory Reconditioned...
I have 2 dewalt 18 volt hammer drills. The first one died about 2 years ago. The trigger seemed to mess up. I took it apart several times thinking I could fix it. I finally gave up on it. It's laid...
Hi, Take the drill apart using a star driver. When taking the chuck assembly from the yellow section have the drill chuch down to stop bits falling out. Once handle is apart popout the triggger assembly. Remove the two power leads from the assembly. Try a direct connection to the battery (polarity doesn't matter. If the motor goes it means that the trigger is U/S. Put a tester across the terminals (either set). You may have a short (as I had). It appears to me that the trigger is not user servicable. I used one from a DeWalt recip saw with a mod on the reverse lever. Works well.
Good luck.
Mar 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My 12v dewalt drill runs like its running low on power even with a fresh battery in it.help!
The problem I have seen is the trigger. I know it's a pain, but that was the the problem with mine......The trigger has an integrated regulator and Rheostat that controls speed and voltage and when she goes,...........That's it! Sorry.....
Dr. Phil
Jan 11, 2010 | Dewalt 18 Volt Compact Drill Kit
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Drill was working intermittently but now it ceased
With the DeWalt cordless drills, the weak link is that the leads tend to burn (melt) off at the motor brushes, It's happened to mine now about 3-4 times, so much so I've had to replace the wires after they got too short to put a new terminal back on them!
The only other issue is that the trigger mechanism could be faulty. but before you spend the bucks on that, you can easily check to see if it't the wiring or the trigger assembly.
Before you take anything apart, make sure the top speed selector is at #1, and the torque setting set to the lowest setting. (makes it easier to remember if you have the speed selector come out of the drill body)
Now lay the drill on it's side and with the battery out of the tool, remove all the screws that hold the two halves together. Take off the top half and look at the back end of the tool to see if the wires going to the motor are in good condition and not burned off the motor brush tabs. If they are, you can either resolder them or recrimp them (DeWalt used different methods for different models) with a new .25 female terminal (any auto or hardware store will have them)
You can give the repair a quick check (IF you are careful) by putting in the battery into the lower drill body and holding the drill motor, gently squeeze the trigger and see if the tool runs. If so, you've fixe it and can put the drill back together.
If the wires are good, then it's the trigger assembly and you'll have to get one from either a DeWalt Authorized service center or distributor that carries repair parts, as these are sealed units and can't be fixed (I've tried). There are some available online too, if you wish to do the replacement yourself, which is a straight forward unplug and plug operation, now that the tool is apart.
Reassemble, making sure the speed selector is in the slots on the tool body and everything else lines up correctly. Install the screws and you're back in business.
Hope you find this very helpful and best regards!
Aug 23, 2009 | Dewalt 18 Volt Compact Drill Kit
Drill stop working after drilling hole in concrete. I can see smoke coming from drill. Now both forward and reverse does not work any more. Is the drill motor burnt out? Or is there a fuse that I can...
With the DeWalt cordless drills, the weak link is that the leads tend to burn (melt) off at the motor brushes when the drill is overloaded. It's happened to mine now about 3-4 times, so much so I've had to replace the wires after they got too short to put a new terminal back on them!
The only other issue is that the trigger mechanism could have failed due to the hevy load of drilling in concrete. But before you spend the bucks on that, you can easily check to see if it's the wiring or the trigger assembly.
You can give the repair a quick check (IF you are careful) by putting in the battery into the lower drill body and holding the drill motor, gently squeeze the trigger and see if the tool runs. If so, you've fixed it and can put the drill back together.
Aug 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DW983K - 2 heavy - duty XRP 1/2" 14.4v cordless drill/driver kit Logo
195 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
