Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool Gas Oven
Getting error on display panel that says: F1E2. I have no clue what this might mean or what can be done to fix it. Please help.....
  • gj_helpme Dec 21, 2007
    When the control and circuit board were replaced, the new panel then displayed the F3E0 error which means 'Oven sensor opened' according to the Tech Sheet. What would be the fix from there?
    Scholar:
  • 146 Answers
The F1, E2 codes mean you have UL ac-dc errors. This means you need to replace the control.
Posted on Dec 21, 2007
  • Kelly Sullivan Dec 21, 2007
    The F3, E0 means you have a bad thermo sensor replace it and you'll be on your way. It's in the range upper right or left corner.
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
F1e2 error code
F1E2 error code usually refers to something with the control board. I do not have info before me, but believe the board has to be replaced.
Package info somewhere inside your stove will give you the explanation of that error code.
It does not hurt to unplug the stove for fifteen minutes/turn it on again and see what the error code is, if any.
Oct 19, 2013 | Whirlpool SF367 Gas Kitchen Range
What does error code f1e2 mean and how to fix it
Problem with the board. First try tightening up the harnesses on the board; make sure the buttons are not stuck, turn oven off and on again and see what the code reads..if any.
Do not have exact explanation for error code but know that that is where your problem lies.
Oct 19, 2013 | Kitchen Ranges
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool oven
if you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
Jan 28, 2008 | Whirlpool SF367 Gas Kitchen Range
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
321 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
