Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Finding lamp in sony wega 50 in tv
Where is the lamp located? I heard a loud pop took off the front cover and cannot locate the lamp to see if it blew.
  • Sony Master
  • 5,138 Answers
Lamp is located in the back, Remove back it will be mounted in a box holding it should have handle to pull it out. For Parts Visit ENCOMPASS on line type in your model number it will lited parts to your set. or call Mats Electronics for Lamp 1-800-628-1118 Once you know Lamp # look for Deals on E-Bay.
Posted on Oct 02, 2009
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I need to replavce the lamp on a KDF50we655 50 " TV. I unplugged all the cables and have turned the TV so the rear is facing me ,, how do I replace the lamp ?
Hi,here's how : http://www.youtube.com/watch?v=b31IYV3IYKs&feature=PlayList&p=B41B05489C4D25D0&playnext_from=PL&index=0&playnext=1 You can find your original lamp xl-2100 right here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?1=1&CartID=0?Click=48173 Have a bless one!
Apr 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a 50 " Sony Wega KDF50WE655
Front panel should unscrew with thumbscrews and pop off and there should be an access cover for the bulb in center.
Apr 13, 2010 | Sony KDF50E2010ATNS 50" HDTV-Ready LCD TV
I am trying to replace the tv lamp on Sony Wega 50 Inch TV; Would like to know where lamp is located so I can replace.
on some models there is a cover on side of tv remove in reach in side (MAKE SURE UNPLUGED FIRST) ther is an other cover(SAFTY COVER )in side with a leaver on it turn ant-clock wise and pull out now reach in and feel for finger ring lift up and pull out lamp and change to put back to gether is revrse make sure to lock SAFTY COVER
UNPLUG
the other model is behind cover on frount of tv to get this off on each side of tv ( BACK CORNERS ) there is two big black srews that can be opened with coin unod they will not come out all the way
then pull the frount cover start at ends of tv ( IT NEEDS A SHARP PULL ) to releace clips then pull middle
once removed you will see a gray cover with big black screw( SAFTY COVER ) undo and remove next you will need ALEN KEY undo two bolts they will not come out all way and pull out lamp replace and revrse above
Dec 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Wheres is the lamp located on the sony wega 50 inch tv
remove the two small covers left and right behind the front lower panel.remove front lower panel (its a firm fit) pull in this sequence 1 rht top, 2 left top, 3&4 lower mid. lamp behind a panel just to the left of cantre, remove two screws locating it in place .pull lamp housing out
Sep 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Replacing lamp for a sony lcd Kdf50WE655
it is located in the front of the set behind either a long metal strip cover or a plastic cover. some sets have wing nuts hoding the cover in place. they would be located on the left and right hand side of the set near the bottom edges.
Jan 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
