Question about Canon DC50 DVD Camcorder
My battery doesn't charge anymore Canon DC50
My battery won't charge inside the camera or even if charged separetely.
The camera doesn't recognize the battery.
Please help!!!
  • albertfs88 Oct 02, 2009
    Hey Joe! Thanks for your reply!
    But I don't think this is the problem. Because I have two batteries, and both of them aren't recognized by the camera, and the problem started at the same time with the two batteries. One of them was bought about two years ago, and the other one about one year ago.
    I'll be thankful if you could help me!
  • 10,865 Answers
It sounds like your battery is shot and needs to be replaced. Before you spend any money on it though, I recommend that you take your camcorder and that battery to a camera shop and have them test the battery and the camera's recharging system.
Posted on Oct 02, 2009
Battery wont charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 04, 2012 | Canon PowerShot SD1000 Digital Camera
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My canon powershot a2000is displays 'change the batteries' even when the batteries are new and completely charged. i am not able to click more than 3-4 pics. these batteries work fine on other...
You most likely have dirty contacts or a loose connection inside the camera.
It might be worthwhile trying to clean the contacts. I would suggest using cotton wool twisted onto a skewer or wooden toothpick. Do NOT use any solvents or other liquids. If that doesn't help then you should seek professional advice ina camera shop.
Sep 17, 2011 | Canon Powershot A2000 IS Digital Camera
Camera won't switch on, put new batteries in it, took a photo to test, since then it won't switch on.
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Jul 25, 2011 | Olympus Camedia D-540 Zoom Digital Camera
My sd 600 wont turn on i even charged it nothing happens
Hi, With how old that model is it's likely that the battery isn't able to hold a charge anymore, I'd suggest buying a new battery to correct the problem.
Jun 15, 2011 | Canon PowerShot SD600 Digital Camera
G7 just dead. can't turn on power. check battery
These G7 powershot cameras sometimes get a short from a loose screw which often leaves the camera with no power. You'll want to have it fixed but with a place that knows of the problem and does the correction inside the camera so that it doesn't keep happening. The place that just does powershots and they do amazing work on these cameras is: www.camerasandparts.com They charge about half of what canon wants to fix this problem and the include the service and the correction to the screws inside so it won't keep happening. It's $89 for everything with them, a great deal and they do superb work on these cameras.
Feb 27, 2010 | Canon Camera Multimedia Projector
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Aug 29, 2008 | Canon PowerShot SD870 IS Digital Camera
Canon DC50 DVD Camcorder Logo
169 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
