Question about Twinhead SlimNote N12PI Notebook PC
Dell latitude 610 AC adapter issue or battery pack issue or both?
My Laptop is DEAD. When I insert the AC adapter into
the back of the laptop the green lite on the AC adapter goes out and nothing happens. Tried 2 similar AC adapters and the same thing happened.
Could this be related to a powerless Battery pack?
Traveling soon and I need my laptop.
Thanks in advance for anyone's help.
  • 1,226 Answers
Umm..same happen that your battery pack hang up. i encountered same problem during our training last year.
My solution is:
1.remove the battery pack.
2.connect the ac adapter and switch on using the ac adapter with out battery pack.
If the same happen,
3. installed back the battery and connect the ac power and switch on.
If the same happen.
4. i have nothing to say because solution 1 to 3 is effective during i encountered the problem.
5. advice in checking the power electronic circuit to the nearest repair center.
Posted on Dec 21, 2007
  • 317 Answers
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Not powering up/power supply led goes out when plugging into into laptop
Step 1:
Try removing the battery of your laptop and try using the ac adapter/power supply alone.
Step 2:
Check your power supply's wiring if it's loose or have some signs of defects on it.
Dec 12, 2012 | Dell Latitude D 600/610
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
I have a customer with a Inspiron 1545 at boot she gets 8 beeps all the same length....hlep!
8 beeps all the same length makes me think its an AMI bios with memory errors, try swapping the memory or check that its correctly inserted.
Mar 17, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
Hi, I have a dell latitude d531 laptop, and today i pulled it out and plugged in the power adapter and pressed the on switch and nothing-not a flicker, no BIOS, not one led flashed. totally dead...i...
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
Apr 29, 2017 | Dell Latitude D531 Notebook
My dell D630 won't power up and the light from the ac adapter turned off whenever I plug it on the dc socket of the laptop. I tried unplugging it and then replugging it back to the outlet the light from...
Please remove the Battery and try to turn ON the Computer and try connecting to any other known power outlet. if the same issue persists, then the service may be required
Jun 24, 2010 | Dell Latitude D630 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
My Dell Latitude 610 won't start. I have tried
I have two old Dell 610, both had the problem of not switching on via the button. It is caused by the design of the tactile switch. Over the years, the mechanism grinds away at the plastic inside, and debris accumulates in the switch. Its tricky to fix. Remove all power leads and the battery. Remove the trim that covers the switch. by inserting a small flat screwdriver into the slot on the right of the trim and levering it up. You can now see the switches. Now use a dressmakers pin to lever away the metal catches on either side of the switch. It's really fiddly but achievable. When both sides are free, lift the tiny metal case away from the body of the switch, the soldered tab at the front will break away but it's not needed. Now you can remove the button, and then the metal disc which forms the contact. You should now see a pile of plastic debris, which you can blow or brush away. Re-assemble the disc and the button, and clip the metal case of the button back on. replace the trim. That's it. I suspect this must happen to many devices with the same design of button, because both my laptops had it. Photo of switch attached dell-latitude-610-start-tried-2c45uiy5yp2yg5vhmsw144sb-5-1.jpg
Nov 17, 2009 | Dell Latitude D600 Notebook
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
Dell latitude D 610 battery dead
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Jun 16, 2008 | Dell Computers & Internet
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
94 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
