LG DLG5988 Gas Dryer
Problem for LG DLG5988 Gas Dryer
I need to convert my gas dryer to propane. I
By dewainbaker on Oct 02, 2009
I need to convert my gas dryer to propane. I already have the orfice. It's model DLG5988S THANKS!!!
Best Solution
posted on Oct 02, 2009
Helpful)
canbruce75
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 844 votes
Here are the basics of the conversion process:
Make sure the gas is turned off and the dryer is unplugged from the power source. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" This is good advice. Thanks! How do you get to the gas valve and regulator? " - dewainbaker
Popular Solutions for LG DLG5988 Gas Dryer
Questions and Unsolved Problems for LG DLG5988 Gas Dryer
Do you recommend LG DLG5988 Gas Dryer?
Answer
Answer
water is backing up through top of vent pipe
Answer
I have an LG dryer (dle2516w) that does not get hot. I took the heating elements out and it is fine.... (More)
Answer
how do I disassemble my dlg5988? It is making a clicking noise when the drum turns
Answer
I have a LG DLE5932W Gas front load dryer. It tumbles but won't get hot. About a year ago a... (More)
Answer
i have a lg dlg5988b gas dryer and it seems to take a long time to dry. I had a electric maytag... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
