A flashing green light on a Swann 960H Pro Series security camera system can indicate a few different things, depending on the specific model and configuration of your system. Some possible causes of a flashing green light include:
The camera is in setup mode: When a camera is first powered on, it may flash a green light to indicate that it is in setup mode and ready to be configured.
The camera is in standby mode: When the camera is not actively recording, it may flash a green light to indicate that it is in standby mode and ready to start recording.
The camera is recording: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is recording.
The camera is low on power: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is low on power.
The camera is malfunctioning : Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is malfunctioning.
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
What can happen is the lens on them can go ofsidded, if the lens is not retracting back in give it a firm push untill u hear a click and turn off and on, hope this helps in some way.
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
I have Olympus FE-270 Digital Camera, whenever I switch on I always see the orange light. What is the cause? How to make it to get green light like others. Please help. Thanks
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
How old are the batteries? They really aren't meant to last more than a year or two. Dieing batteries may show green in the charger, but only hold the charge momentarily.
