Question about Brother HL 1440 Laser Printer
Need a ppd for printer. New computer does not acknowledge printer.
    Genius:
  • 1,341 Answers
Check compatibility of new pc with the printer.You may need to install the driver on the pc etc,but check the version if it is compatible with the software operating system.
Posted on Oct 02, 2009
How should I open my WeP Dotmatrix printer top panel to change the board
Sir/Madam
You Need To Go Below URL Link and download Some file To Fix your Epson Printer Problem,I Hope after Download file and follow instruction metion on the URL Link Site You able To Fix Your Epson Printer problem :
SOLUTION
  1. Download the attached file(s). You will probably just need the 24-pin PPD, but I have also included the 9-pin PPD (which I haven't tested) just in case.
  2. Browse to the CUPS web interface at http: // localhost:631
    NOTE: The printer installer system from the GUI will NOT work. It will throw an error and promptly fail
  3. Create the printer listing using the CUPS web interface, and when it asks for a PPD, point it at the one you just downloaded
  4. PROFIT!!
I hope this helps someone, ANYONE who has been in the same straits I have been.
So man your chips, and may The Source be with you!
Thread Working with WIPRO WeP and Epson dot matrix printers
Or
You Still having Brother Printer Problem then Follow Us On:
Epson Printer Support
Jul 12, 2011 | Epson Office Equipment & Supplies
How can i install canon pixma ip1980 for ubuntu 10.10
1) Download and install this: http://www.ziddu.com/downloadlink/2820548/driver_iP1880.zip
You can just extract the file and double click on the .deb file.
2) Open System ? Administration ? Printing ? New Printer, to Select Connection chose Canon ip1800 series USB #1
3) in Printer driver chose: Provide PPD file
4) point that at: /usr/share/cups/model/canonip1800.ppd
5) Give the name of ip1880/ip1700/ip1980 ? Apply
6) Restart the computer
7) open the terminal and write: cd /usr/lib After that, press Enter
8) write in terminal: sudo ln -s ./libtiff.so.4.2.1 ./libtiff.so.3 press Enter
9) Now it should work
Feb 28, 2011 | Computers & Internet
My LQ 300+ is not compatible with my windows vista
More comprehensive information to those who are looking to use the Epson LQ-300+ with Ubuntu.
You can download the ppd from http://www.cups.org/ppd/epson/en/eplq300.ppd.gz
I just copied the .gz (don't extract the ppd) file to /usr/share/foomatic/db/source/PPD/Epson/
(not sure where else I can put it).
Goto System->Administration->Printing and add a new printer. I have connected the printer with one of those cheap USB to Parallel cables. The printer is detected as EPSON LQ-300+
Select driver under Epson and you should see it listed as LQ-300+ 24 pin.
CAUTION!: The max resolution you can use under "Printer Options" is 360x180dpi. DO NOT select the highest 360dpi setting - your printer will go crazy and eat-up all your paper.
It works for me. I hope it works for you too.
Nov 03, 2009 | Epson LQ 300+ Matrix Printer
Cannot locate PPDs for this printer in printer menu when printing out in quarkxpress
Launch QuarkXPress and go to Utilities>>PPD manager and update the ppd's from here
Oct 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
What "Printer" to choose?
Your pronter should have come with a driver disk. You should disconnect your printer from the computer and run the installation from the disk. When prompted, connect the printer to the computer to complete the installation.
May 17, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
OS-x driver for Brother HL-730 (600dpi) printer
Macs don't use drivers, but rather .ppd files.  you should be able to download the PPD from brothers website:  http://www.openprinting.org/ppd-o-matic.cgi?driver=hl7x0&printer=Brother-HL-730&show=0
(Direct Download Link)
When you are in system settings, goto printers, select the network printer, and when you get to choose the PPD from the pulldown menu choose "Other" and you should be able to browse to the PPD you downloaded.
you are using a UNIX based system.  The Linux PPD should work just fine.
Apr 08, 2009 | Apple iMac G4 Desktop
Color on monitor different from print
Windows 2000 / XP
  1. From the application's File menu, select Print to display the application's Print dialog box.
  2. Click the Properties button located at the top, right of the Print dialog box to display the printer Properties window.
  3. Click the TekColor tab.
  4. Select a TekColor correction. It may be necessary to try all the color corrections to obtain the desired results.
  5. Click OK to return to the Print dialog box, then click OK to send the print job to the printer.
Windows 98 / Me
  5. Click the Apply button at the bottom, right of the Printer Properties window.
  6. Click OK to return to the Print dialog box, then click OK to send the print job to the printer.
Macintosh OS 9
  1. From the application's File menu, select Print.
  2. Click on the General drop-down list and select TekColor.
  3. Select a TekColor correction. It may be necessary to try all the color corrections to obtain the desired results.
  4. Click the Print button to send the print job to the printer.
Macintosh OS 10 (10.2.x and 10.3.x)
  2. Click the Copies and Pages drop-down list and select Image Quality.
note_image33x30.gif Note: If the image quality option is not displayed, refer to configure the printer with the correct PostScript Printer Description (PPD) File Below. Configure the Printer with the Correct PostScript Printer Description (PPD)
note_image33x30.gif Note: The steps below are only necessary if the Image Quality option is not available in Macintosh OS X. The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed. To ensure the printer is configured with the correct PPD file:
  1. Open the Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Open the Hard Drive.
    2. Open the Applications folder.
    3. Open the Utilities folder.
    4. Open the Print Center or Printer Setup Utility.
  2. With the Print Center or the Printer Setup Utility open, select the appropriate printer from the printer list, then click Show Info from the Printers menu.
  3. Click the Name and Location drop-down lsit and select Printer Model.
  4. The current PPD being used will be displayed. If the PPD shown is incorrect (for example; is set to Generic PostScript Printer), click the drop-down list and select Xerox.
  5. Select the corresponding PPD for the printer and click Apply Changes. note_image33x30.gif Note: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, ensure the DP feature set is selected.
  6. Close the Printer Info window, close the Printer List window, then check that the Image Quality option is available.
Nov 05, 2007 | Xerox Phaser 8400 Laser Printer
Need the actual PPD file for the 8860dn printer
http://forums.linux-foundation.org/file.php?24,file=25
Oct 16, 2007 | Xante Accel-A-Writer 1200 256MB Memory...
No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Oct 08, 2007 | Ricoh Aficio BP20N Laser Printer
Brother HL 1440 Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
