Question about D-Link DI-614+ /DWL-520+ Router
Having issues with resetting the D-Link 614+ router. I need to change 1 simple option in the router; however, somehow the admin log in will not accept the password "I think" I made for it. I have tried using the reset button(held it for 10seconds, up a to min , and even longer), yet it still has the password or whatever enabled. I have tried keeping it unplugged for hours and hoping it would reset... but to no avail. Is there a command prompt command, a file I can download, or anything at all I can use to access this router? I am really confused, but really want this thing to work out. ( The setting I need to change is the mps, it is capping my net at 2.5 at the most, which i have plenty more to spare than that because I am connected to my modem and get at least 2x that).
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 02, 2009
How do i change my password
Log into your router's administration page (typically at http://192.168.1.1 by default). There will be a menu with options for various admin tasks. Change password will be listed as an option. If you do not know your admin password to log into the website, you can do a factory reset on the router to blank it back to 'out of the box' settings by unplugging the router and holding in the reset button on the back for 5 seconds while powering on the router. Once reset you should be able to log in with a username of admin and password of password. Once in after the reset the router will walk you through the initial setup steps again and you can choose a new password.
Dec 22, 2013 | NetGear Computers & Internet
I have a linksys-N router cannot remember my username and password. Where do I start to retrieve this information
If you are having problems logging on to your linksys n router. you have to options to log on with the default. the usual default username and password is admin.
if that does not work. try leaving the username blank then the password is admin, third is type admin as password then leave the password blank.
if the options didn't work, there should be a reset button at the back of the router. try pressing it for about 5-10 seconds. the default username and password would be restored. Yo can also try going to this link.
Hope this helps.
thank you for choosing fixya.
Jun 10, 2011 | Computers & Internet
How do I access the router control panel?
The factory default User name is admin and the default Password is blank (empty). It is recommended that you change the admin password for security purposes. Please refer to Tools>Admin to change the admin password.
You need to download the user manual. ftp://ftp.dlink.com/Gateway/di614+/Manual/DI-614+_manual_06292005.zip
May 01, 2011 | D-Link AirPlus DI-614+ Wireless Router
Need to know the passphrase for the wrg 614 v7
The paraphase is something the owner sets up. you can log into the router @
192.168.0.1 OR www.routerlogin.net. Use the default username (admin) and password (password) .
Go to Wireless, then security. you will see the paraphrse there.
If you need to reset the router do the following:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | NetGear WGR614 Wireless Router
I am having trouble connecting my new Macbookpro to the wireless network in my home using a D-Link router (WBR1310). It doesn't seem to like the password which I have on record.
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
  • How do I find my routers IP Address, in Windows XP?
  • How do I reset my router back to the factory default settings?
    (NOTE: To reach the configuration page of your D-Link router in Mac OS, you will need to use a Java compatible browser such as Firefox or Camino.)
    (NOTE: Some routers have a "Captcha" graphical login option. This option can be disabled in the advanced options of the routers configuration.)
  • Nov 07, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
    When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
    default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
    Default username: admin
    Default pass: leave blank
    If you are still having issues let me know.
    Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
    Unable to write network settings to device error code 0x8004d112
    1. this error is not recognizable.
    But here is the D-link site for updating your firmware for the DI-614
    this may resolve your issue.
    http://www.dlink.com/products/?pid=DI-614%2b
    2. You also may want to check the status of you router by logging into it and checking the "status" page (192.168.0.1)
    User : admin
    No password unless specified
    This will tell you a lot as to what the router is doing and not doing.
    Jun 18, 2010 | D-Link AirPlus DI-614+ Wireless Router
    Got a d-link router and somehow i tried to put in a password then after that it locked. how can i unlock it or reset to original setting.
    Try looking in the main settings of the router.
    Type the IP address of your router into your browser e.g. Internet Explorer, log-in, usually your password is the same as your log-in name.
    I have a D-Link router and my Login Name is admin and my password is admin.
    Hope this information helps you!
    Feb 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
    How do i change password on wireless router
    hello, two things first if you know the current password and would like to change it to something else: simply log in to the router using the current password and once logged in look for "Maintenance" section and uder it you will see the option called "Set Password", click on it and then you will see three input fields "Old Password", "New Passwor", and "Repeat New Password", fill in all the fields and click apply and you are done.
    second, if you have forgotten your password then the only option you have left is to reset the router with a paper clip (in reset hole in back) but keep in mind you will lose all settings and you will have to reconfigure it. Once the router is reset you can change the password same way i mentioned above.
    here is a link that describe step-by-step how to reset and connect back to router to log back in.
    http://kb.netgear.com/app/answers/detail/a_id/59/session/L2F2LzEvc2lkL2wxVHBYdlBq
    Hope this helps,
    Regards,
    Amar Sondhi
    Dec 15, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
    I cannot set password
    There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
    If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
    Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
    D-Link DI-614+ /DWL-520+ Router Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
