open up the e-mail section
try this in the home tab go to the file tab ( tab next to message tab)and open new message
along the top bar you will see a contacts tab with add and check names
click on the add tab and that opens up select contacts to send e-mails to
that shows all the contacts with their e-mail addresses
highlight the address you want to change and up the top you will see a section edit contact
click on that and that contact details will open
here you can delete or change the address or add any other details for that contact
save down the bottom
some times the unread messages go back to the last instead of coming to the first.So if you are viewing first 25 mails ,please go to the last 25 mails and you will definitely get your unread mail
There is a problem with Yahoo's connectivity to your computer and vice versa. This can be resolved by hitting F5 or refresh for a couple of times until your inbox comes in.
You could try going to your Tool Bar and choosing Internet Options. Then change whatever address is in your homepage box to www.yahoo.com and restart your computers. It may allow yahoo to work. good luck!
You may check out Wii Fix Guide
to fix the problem yourself. This DIY guide will show step by step
pictures to fix the problems yourself without any technical knowledge.
Either you're clicking on the wrong spot, or your computer is freezing up. Does the link change color or light up right when you click on it? If so, it's not the link. Does your computer freeze up or does it just act like the links are useless?
