Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Fridge and freezer will not cool down
I have just got my fridge out of storage (about 6 months), we went to plug it in and it won't cool at all, it heats up and becomes quite humid. are you able to tell me the problem with our fridge? it is a kelvinator, twin air, no frost 400. htankyou for your help
  • 69darocket Dec 21, 2007
    the compressor works intermittently and i've checked the thermostyat controls and moved them. still nothing
  • 833 Answers
69....hard to know from here. What heats up and becomes quite humid? Newly restarted refrigerators take about 12-24 hours to cool down. They should be opened very infrequently during that period, if possible.. Do you hear the compressor and fans? Have you properly set the cooling controls?
Posted on Dec 21, 2007
  • Robert Hirst Dec 21, 2007
    The compressor should be cycling on and off according to temperature...about 15 minutes per hour...and there should be cooling. First, clean the condenser coils in the bottom of the unit. Then, turn the unit on after resting for an hour or so. The largest pipe on the compressor should get frosty and then either turn to liquid water, ice or dry out after about 5 minutes...not less. Stays frosty...needs gas. Short cycle...get a service tech in. You may need a motor start relay.
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
Side by side wirlpool fridge freezer not cooling down
make sure the fan motors are running. there is one near the compressor in the bottom rear and one in the freezer area. also be sure the compressor is running. being it was in storage there could be rust on the motors or possibly a mouse could have chewed through some wires.
Oct 28, 2008 | Whirlpool Refrigerators
Refrigerator not cooling
My fridge and freezer just stopped cooling all of a sudden. I hear the compressor running and every couple of min there is a clicking noise. Is there a reset switch or something that I can do to start it working again? The lights are working but the freezer and fridge are room temp.
Jun 22, 2008 | Refrigerators
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
163 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
