Question about Toshiba 43HX71 43" Rear Projection Television
Toshiba 43HX71 projection TV Convergence problem
After reading some of the posted solutions, it appears that I have a convergence problem with my Toshiba 43HX71 projection televison. I start to get the 'shadows' after the TV has been on for a while. If I shut it off for about 30 minutes and turn it back on then it is okay for a whle. I read where the 50H71 convergence kit works for my Toshiba 43HX71 projection model. Is this true?
Do installations directions come with it?
Are the convergence ICs easily accessable when I open the back of the TV?
thanks for any help you can provide
  • 4,234 Answers
Since the set seems to correct itself when "cool", I would first try resoldering the convergence IC area. Quite often, the convergence problems start with poor connections that eventually cause the ICs to fail. Rather than spending money on a repair kit, try the resoldering first. I will verify the kit contents in the meantime.
Please keep us posted on your progress.
Dan
Posted on Oct 02, 2009
Testimonial: "Yes, this was helpful"
The picture has hues orf red and appears dark in night shots.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Looks like its in 3d red and green
  • Screen looks 3D
69189a5.pngSOLUTION
May 14, 2011 | Hitachi 43F300 43" Rear Projection...
The blue convergence is off at the bottom and doesnt readjust using the option.. can it be fixed?
  • Screen looks 3D
69189a5.pngSOLUTION
May 09, 2011 | Toshiba 50A61 50" Rear Projection...
I have a Toshiba 42H81 42 in. Rear Projection Television. The picture has shadows like you would watch a 3D image without glasses. I ran the focus on it and the vertical red has noise in it and at the end...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 31, 2011 | Toshiba 42H81 42" Rear Projection...
Picture appears to be 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
Double image in 2 colors one color red ofset above and at about 30 degree angle
The convergence needs to be repaired. The 50H71 convergence kit works in your model as well. You can get the kit at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Jul 11, 2009 | Toshiba 43HX71 43" Rear Projection...
My TV is showing a double picture
If the picture looks like a 3D one, the problem is a convergence issue. This can be as simple as poor connections at the pins of the convergence ICs or defective ICs. If you can solder you can probably fix this yourself. Please note that there are potentially dangerous high voltages inside the set even when unplugged.
If you wish to attempt the repair, please update this and I will provide additional details and instructions.
Dan
Mar 02, 2009 | Toshiba 43HX71 43" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence problem
I have double lettering in my tv titles
Aug 05, 2008 | Toshiba 43HX71 43" Rear Projection...
Toshiba 43HX71 43" Rear Projection Television Logo
301 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
